Old 04-23-2004, 11:43 PM   #1
jhow66
jhow66's Avatar
Sway bar ?
Did any 72 Blazer come with sway bars (4X4)? If not will 4X4 PU work?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-24-2004, 09:31 AM   #2
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I've never seen a factory sway bar on 4x4s of our era. I think they became standard in '73. The '73-up sway bar axle brackets will bolt in place of our truck's non-sway bar axle brackets. The upper bracket would need to be fabbed. I've thought about doing this to mine, but the fabbing of the upper bracket has things on hold.
badpeanut is offline   Reply With Quote
Old 04-24-2004, 11:03 AM   #3
jhow66
jhow66's Avatar
Thanks--may try it -will let you know.
Old 04-24-2004, 01:31 PM   #4
Jimmy72custom
Jimmy72custom's Avatar
This is the mount I made. Hope the pic works, first try.
I do need to make or buy quick disconnects for axel end.
That did't work
Lets do it this way
http://www.imagestation.com/mypictur...ar%20mount%20l
Jimmy72custom is offline   Reply With Quote
Old 04-24-2004, 05:47 PM   #5
badpeanut
badpeanut's Avatar
It is fine to run with the sway bar connected all the time (use the '73-up axle brackets), but the hard core off road types use disconnects to increase axle articulation. Unless you fall into that category I'd suggest you save your money and not buy the disconnects.
Old 04-24-2004, 08:49 PM   #6
Jimmy72custom
I was thinking more of the up and down movement of the Jimmy during normal or off road driving. I do have 73 axle brackets. Since the sway bar is an add on, I don't think the geometry is correct, the sway bar and the front springs don't move in complete harmony. the anti sway bar bushings are becoming oval. Quick disconnects will give a pivot point at the axle which should save my bushings and improve my ride.
Old 04-24-2004, 10:37 PM   #7
3wbdriver
3wbdriver's Avatar
Why not get a kit that bolts right up?
http://www.gmcpauls.com/Suspension.htm
'72 Blazer, 4WD, 350/4 spd. Affectionately known as "Da Beast"
'04 Silverado (new daily driver)
'00 Intrepid (wife's ride)
It's a BLAZER dude! No options, no emblems, no a/c, no fancy shmancy. It's a BLAZER....
3wbdriver is offline   Reply With Quote
Old 04-25-2004, 01:15 AM   #8
Jimmy72custom
That's cool I did not know that there was a sway bar made for the first gen K5. The only problem is the geometry would still be off. I have a 4" lift the original spring was shorter from the front shackle to the axle.
Old 04-25-2004, 01:41 AM   #9
jhow66
jhow66's Avatar
Thanks everybody! Good infro. The lift kit that my son (orangeuavol) ordered comes with a bracket that adjusts the sway bar back to the right geometry. This was the reason that I figured someone made a sway bar for his Blazer, I just could not find it. Will check with GMCPauls to see if it will work with a lift kit. By the way it will be used on road only. Now if we could find one for the rear!!
Old 04-27-2004, 12:17 AM   #10
earl87gta
earl87gta's Avatar
Ive got one on my 72 if you dont have one buy the next time I go threw to Murfreesboro I will bring it to you with the braket I used to make it work for how a bought $30 for all of it. I used it with 6in suspention and 3 body lift Ill take pics tomarrow why I have the cammra here.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 04-27-2004, 01:10 AM   #11
jhow66
jhow66's Avatar
Sounds good there Earl! This is our 1st attempt at building a 4X4 so we are not up on all the in's and out's. I checked with GMCPauls and they said their sway bar for the front was for stock height only but I think we can make it work. Was you talking about the front or rear sway bar. Looking forward to the photos.
Thanks,
Howard
Old 05-01-2004, 02:27 AM   #12
earl87gta
earl87gta's Avatar
jhow66
I will be moving to Johnson city in a week If you want you can stop buy and take a look at the sway bar on the blazer.
Earl
Old 05-01-2004, 08:05 AM   #13
jhow66
jhow66's Avatar
Thanks for the invite.
