Old 04-24-2004, 01:54 AM   #1
Patch
Patch's Avatar
Unhappy Noise?
Hi all......In my 72 Blazer...at about 50 miles an hour...when I let off the pedal....I get a racket from the transfer case.....it's not a grinding.....but it is a hell of a racket...and vibration through my t-case shifter handle.....could it be the input bearing? This is in two wheel drive.....and I have a T350 tranny.....Thanks in advance.....
P.S. Keep our troops in your thoughts...they deserve it.
Patch
Patch is offline   Reply With Quote
Old 04-24-2004, 09:06 AM   #2
71swb4x4
71swb4x4's Avatar
I would check the mount and the U-joints before tearing into the T-case, just to be sure its not something inexpensive and easy to replace.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-24-2004, 12:10 PM   #3
Patch
Patch's Avatar
Maybe
The rear driveline joints are brand new....I havent checked the front though......but I will.....thanks.
Patch
Old 04-24-2004, 02:03 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
My first guess would have been the u-joints too. Also check your t-case shifter linkages, they may be loose and rattling.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-25-2004, 01:30 PM   #5
ericguy320
I would check the rear end pinion bearing, put in N with the park brake on and see if there is any slop up and down at the yoke. mine did the same thing on decel, the pinion nut had backed out
http://community.webshots.com/user/ericguy320
1972 Chevy C10 SOLD
1972 k5 blazer cst 350, sm465, rust
1993 gmc Typhoon for sale $13,900 obo
1980 Ironhead Sportster
ericguy320 is offline   Reply With Quote
Old 04-26-2004, 11:30 AM   #6
smokekiki
Mike
smokekiki's Avatar
Same as ericguy320 said.I had a pinion nut come loose.Sounded like it was in the transfer case.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 04-28-2004, 12:52 PM   #7
Dragonslayer
I agree w/ Smoke and Eric. I was having the same sound. I had about 1/2inch slop in the rearend in neutral. The noise was transfering up the driveline, making it sound like was coming from xfrcase.
1972 Blazer CST 4X4
Dragonslayer is offline   Reply With Quote
