Old 01-02-2018, 12:41 AM   #1
68chevystepside
68chevystepside's Avatar
Exclamation 04 Tahoe Timing Cover Seal Install Help!!
I'm in the process of replacing my timing cover seal for 04 Tahoe engine that will go into my 68. Just wanted to know if anyone has a recommendation on how to install it with out damaging when the cover is put onto the engine? I've seen the tool online but i was hoping i wouldn't have to buy it. Is it possible to install without the alignment tool or is it best to buy the tool? If i do need the tool which do you guys recommend? Thanks
68chevystepside is offline   Reply With Quote
Old 01-02-2018, 07:23 AM   #2
ls1nova71
ls1nova71's Avatar
Re: 04 Tahoe Timing Cover Seal Install Help!!
You need the tool to align it since there are no alignment dowels on the cover. I have put them on loose before though, then installed the balancer/crank pulley, then tightened the cover with good results.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-02-2018, 04:23 PM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
What he said. Press on the balancer, give it a spin, then tighten your cover bolts
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
