[Pic Request]: Throttle Return Spring
I could use images to help sort out the throttle return spring mounting location on my mutt* of a 1969 K10. As inherited, the spring was hooked on ahead of the the carburetor on the very frayed jacket of the radiator hose (bottom image). Thoughts?
*Relevant info Truck: 1969 K10 (Manual) Engine: 1977 (Mark IV) 454 Carburetor: 1973 R4-4MV Rochester Quadrajet |
![]() Join Date: Oct 2014
Re: [Pic Request]: Throttle Return Spring
You can source a spring that fits in between the tab below where your throttle cable attaches and the tab with the hole in it under the cable bracket on the rear of the carb. Find a spring that has tension on it when the throttle is closed.
Lokar sells a dual spring that might fit there. http://www.lokar.com
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
RodnRudy is spot on, use GM style dual return springs. with two springs if one falls off or breaks, your carb doesn't stick wide open.
Parts houses should have Dorman P/N 59207 in stock, it has multiple sets of double springs. Borrowed this pic: |
Who Changed This?
![]() Join Date: Jan 2013
That should work fine. Mine is pretty much like the OP's except that the spring(s) should be in the hole in front of the stud, not on the stud. The setup pictured will not work if the truck is equipped with a 400 transmission, since the kick down switch lived there. He has a manual trans, so it's all good.
![]() Join Date: Jul 2015
I believe according to official stock trucks they had springs on both sides. It will balance the shaft so it does not wear improperly.
Check me on that, Specialty Retail sell thermostat housings that have the proper tab with hole for the spring location you have on it now. |
Thanks all!
Ended up ordering the return spring off of LMC since I was already placing an order. Works great!
Tags |
454, quadrajet, throttle linkage, throttle return spring |
