#751 | |
Re: S10 Swap how to
#752 | |
![]() Join Date: May 2007
Re: S10 Swap how to
![]() ![]() ![]() the belltech blazer spindles bolt right to the s10 truck arms. change the bearings as a 'while you are in there', use timkin bearings if you can, and use new rotors and pads. my rotor shows dust because I had a rock in the pad and these pictures were taken when changing the bad rotor/pads.
#753 |
Re: S10 Swap how to
I found some bad pictures of the firewall pass thru for that big grommet-ed hole, look in the upper right of this picture above and beside the booster
Joedoh ![]() and this is the distribution block that mounts underhood. ![]() Joe Doh, on Flickr[/QUOTE] Thanks for those pictures and insight joedoh. It all looked pretty daunting at first but now after looking at your pics and revisiting all my wires on the ground it seems relatively straight forward. Just mount the wiring bracket on the firewall and hide everything up in the dash |
#754 |
Re: S10 Swap how to
yeah depending on what model s10 it came from there can be a lot to hide but the only really extra thing is the HVAC and radio wiring, everything else gets used.
#755 |
Re: S10 Swap how to
I took every ones advice and managed to successfully shorten my extended cab short bed frame! It went smoothly and I plan on starting my own build thread soon, but for now here are some pictures.
#756 |
Re: S10 Swap how to
Doing this swap on an S10 short wheel base which I moved the rear end back 8" on. Everything has been going as planned but just ran into a snag and hope someone else may have already solved this. The gas tank will not fit under the cab and front of the bed because the cross-member it mounts to is about 8" farther forward than it should be. Has anyone else run into this problem and is there an easy solution? Really don't want to spend $400 on a gas tank and then lose the ability to have a spare carried under the back of the bed. Thanks for any insight you guys may have.
#757 | |
Re: S10 Swap how to
the gas tank crossmember is held in with rivets, and the front strap is bolted in. you can drill the rivets in the crossmember and slide it back in the frame, and redrill new holes for the front strap bolts. you shouldnt need 8 inches, only a couple inches to clear the top of the tank where the stepdown is. keep in mind, the further you move it back the higher it will get. I did this on my 65 which was a std cab stretched the same as yours, because the gas tank hit the floor (it was the stock s10 floor) when I moved the cab back. in the original position the floor did not hit the tank. this is also pretty common to do on bagged s10s because the gas tank hangs ever so slightly below the frame. I would double check the height of your body mounts, if you are mounting the body super low for a slammed stance, you will have this problem even with a longbed truck.
#758 | |
Re: S10 Swap how to
I am not going really low so that should not be a problem. I will go look at how far back I need to go. I measured when I found the problem and the frame flattens out before you can get 8" back so cannot move the cross member back 8" but like you said may be able to go back less. Thanks Last edited by ThadandDad48; 01-19-2018 at 03:56 PM. |
#759 |
Re: S10 Swap how to
Think I have the tank location problem solved. Followed the advice to move the cross member back but ran into issues with not being able to move it back far enough sooooo. Since I Already had the cross member out I ended up replacing it with some 1.5 square tubing clamped to the underside of the top frame rail. I will eventually weld this in place all around and probably add a gusset to the bottom of the frame rail but for the moment this looks like it will work great sets the tank about 3/4" below the bed floor (already raised 3" to allow clearance to frame and get running boards and bed to align properly.) I need to take pictures so I can share but user beware the short frame extension does come with other issues although the 3" drop in the rear has made everything sit level and giving me the stance I was looking for without having to lower anything yet. Current stance is 9" from the bottom of the running boards to the ground which I think looks great and should be very drive able for a 16 year old.
#760 |
Re: S10 Swap how to
sounds like a good solution! I didnt have this problem on the 65, I moved it back less than 3" and it cleared the floor.
how tall are your body mounts? if you needed a 3" raised bed floor that sounds higher than I usually raise the floor, and that would mean the body is lower on the frame. did you use stock s10 body mounts?
#761 |
Re: S10 Swap how to
I used the rev 2 old sarg. (skymangs) body mounts. Which I thought would give a level bed with no bed depth loss, but I am using a 2001 frame so may be a little different in rear frame height. I need to take some pictures and upload so others can learn from my suffering.
If the only tool in your toolbox is a hammer all problems begin to resemble a nail. Project: Thad's first truck our 4.3 4l60e S10 48 Chevy 1 ton to 1/2 ton short bed http://67-72chevytrucks.com/vboard/s...d.php?t=750872 Last edited by ThadandDad48; 01-21-2018 at 03:03 PM. |
#762 | |
![]() Join Date: Sep 2016
Re: S10 Swap how to
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
#763 | |
Re: S10 Swap how to
[IMG] ![]() ![]() Note the new cross member is still held in place by c-clamps.
If the only tool in your toolbox is a hammer all problems begin to resemble a nail. Project: Thad's first truck our 4.3 4l60e S10 48 Chevy 1 ton to 1/2 ton short bed http://67-72chevytrucks.com/vboard/s...d.php?t=750872 |
#764 |
![]() Join Date: Apr 2010
Re: S10 Swap how to
my mounts are meant to have s10 body mounts on them
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
#765 |
Re: S10 Swap how to
skymangs,
Can you provide details on how to fit the original Steering wheel with the gearhead enterprises steering column you discussed. |
#766 |
Re: S10 Swap how to
I am using s10 body mount bushings with your mount design thanks for the dimensions as it sure made getting things right much easier.
#767 |
Re: S10 Swap how to
I think it just looks like you might have the bed floor higher than you actually need it, I usually set it up so the floor sits on that high point of the frame over (what was) the center of the axle. its a good place for a floor if you are bagging the truck though, where you have it, because you need just the tiniest of a notch to lay out and the pumpkin will actually hit the floor where I set it up.
#768 |
Re: S10 Swap how to
I've done that on several of my builds. check out sean s -53 Chevy, cecil. basically you gotta buy a new horn retainer, drill 2 5/16th holes in it. be sure to align one hole with the factory feed wire, put the other hole about opposite the first. then you'll need to cut a small tab of 18ga. bend it in a 90deg angle, then weld it to the lower plate in such a way as that 1 piece sticks through the second hole not touching the upper plate. when you put it on, plug the ground into your welded tab. you see on the new column is energized on the top plate and grounded through the bottom. The original column energized the lower and grounded the top. we just need to find a way to reverse it. you will have to take about a 1/2" off the back of the wheel, you can use a grinder, it's just bakelite. I've tried used retainers 3 or 4 times, they never work. clear as mud, huh
for the wheel just shave it flat. I don't have a picture... then I go to the plumbing section of my local hardware store and buy a black rubber 4" pipe cap, to cover the guts of the column. here's some pictures.
#769 |
Re: S10 Swap how to
this is what I do with the steam tubes. I just hook a hose straight from the tubes to the back of the wp. I use a 1/8" tap and a 1/8" 90 degree brass elbow with 1/8 NPT threads, never cap the steam tubes, they pull condensation from the heads. they are especially important in the winter!
#770 | |
Re: S10 Swap how to
#771 |
Re: S10 Swap how to
Hi Guys, I'm exploring my options to do an S10 swap and was wondering if many have left part of the S10 cab floor, firewall, brake assembly and blended the old cab to that? I'm using the stock 4.3 motor and know its recommended to move it back, but if you could use a push fan in front and leave the motor and firewall, it would sure make for a quick swap. Thanks,
#772 | |
Re: S10 Swap how to
The S10 swap dimensions and mounting points revolve around the center hub of the front wheels. The front fenders need to be centered over the wheels. That then dictates where the radiator and cab are situated in relation to the fenders. Unfortunately, those requirements also mean the engine can't stay where it is. I tried, I failed. Oddly, the moving back of the engine and getting a different drive shaft isn't even the hard part of the swap. You'll find a few build threads on here, including mine, where parts of the firewall are used from the S10. The brake booster and pedal are also used to make the swap much easier. Definitely read some build threads on S10 swaps. I learned almost everything just from reading the builds here and I now have a running driving truck. Best of luck with the build!
#773 |
Re: S10 Swap how to
Thanks for your reply Gigamanx! I totally understand. Is it possible, or advantageous to use all the fire wall with brake/booster,electrical parts, etc, from the S10 and fit onto old cab?
#774 |
Re: S10 Swap how to
i have done it, saves a lot of time. this is the result on the latest 41
#775 |
Re: S10 Swap how to
Great. Thanks for the photos. So really the only portion of the fire wall worth using is where the brake booster and pedal mount?
