Old 01-10-2018, 11:44 AM   #1
blazer2007
255x70x15 on a 10 in.rim
I found the right tire height I like on my Blazer which has a notch and bags. The tires are on a 8 inch rally rim but I don,t like how far the tire sits inside the truck and I want to bring it out to match the front and I don,t think I want to use a 3/4 or 1 inch spacer so I wanted to use the Wheel Vin. 10 inch rallys.I think the Blazers need a taller tire as the blazers are such a big looking box.
blazer2007 is offline   Reply With Quote
Old 01-10-2018, 01:57 PM   #2
blindbug
Re: 255x70x15 on a 10 in.rim
I'm not sure of the question, but I think it's recommendations on Wheel Vintique's 10 inch rallys? Squarebody Syndicate has his formula up on his site:
http://squarebodysyndicate.com/sbs-formula.html
He uses Wheel Vintique's 15x10" with a 5" backspace in the rear. It looks like the outside face of the front and rear tire align with each other. If you are asking something different, I apologize.
blindbug is offline   Reply With Quote
Old 01-10-2018, 04:42 PM   #3
wilkin250r
wilkin250r's Avatar
255/70R15 is just a hair over 10 inches wide. (255 is theoretically 255mm wide, which is 10.04 inches. Sidewall flexing outwards might bring that to about 10.5 inches)
In my experience and research, fitting a 10-inch wide tire on a 10-inch wide wheel only works with low profile tires, where the second number is 50 or below, really short sidewalls. When you start getting into the taller sidewall tires (where the second number is 65 or more), you really need the wheel to be a couple inches more narrow than the tire itself.
It's looking like most manufacturers of 255/70r15 tires recommend a 6.5 to 8.5 width for the wheel.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 01-10-2018, 06:35 PM   #4
SCOTI
SCOTI's Avatar
I wouldn't do a 255/70 on a 10.
A 275/60 looks square & I've used that size many times. If you want a taller rear tire than that, a 285/70 is available from Coker (BFG/Silvertown series).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-10-2018, 09:45 PM   #5
blazer2007
I did have a 285x70 on the back but it just looked too tall and didn,t look right,old pic but get the idea. Maybe a Hoosier or M.T. tire at 29 in. might be worth looking at, Just the 255x70 are brand new. So hard to get the right look with tires and rims , the blazers are so boxy
Old 01-10-2018, 09:47 PM   #6
blazer2007
fronts are are 235x70 if helps
Old 01-10-2018, 10:48 PM   #7
SCOTI
SCOTI's Avatar
285/70-15 comes in around 30.7" so the Mickeys @ 29" would be a good compromise.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-11-2018, 08:49 PM   #8
bbbc10
Diggin The SquareLife
I know its not a blazer but I had 275/60/15 on my wheel vin 15x10 rallys
bbbc10 is offline   Reply With Quote
Old 01-12-2018, 01:50 PM   #9
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I agree that that is a wide wheel for the tire size. If you’re buying new wheels, why not see if wheel vintiques will build a 15x8 with custom backspacing.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 01-12-2018, 02:55 PM   #10
MikeB
MikeB's Avatar
FYI, this is a 255-70x15 on an 8" wheel. I personally think a 10" wheel would look too wide with a 255 tire.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-12-2018, 07:58 PM   #11
blazer2007
The 255 on a 8 inch rim does fit perfect. I,ll see how long wheel vin. takes and charges for a custom rim. In the winter a guy just starts getting pickey and spend more money lol
Old 01-13-2018, 06:18 AM   #12
thinair
thinair
thinair's Avatar
I also have the 8s and 10s and was thinking 255-70s rear and 235-70s front. I wanted the taller tire in the rear because I like the look filling the wheel well better than the top of the well just sitting on the tire like the look of the 275-60s. Truck has a 4 1/2 - 6 drop.
thinair is offline   Reply With Quote
Old 01-13-2018, 09:30 AM   #13
SCOTI
SCOTI's Avatar
$25 per wheel additional charge for changing backspace w/4-6 week lead time & you have to pay shipping vs a distributer (Summit/Jegs).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
