01-11-2018, 02:43 PM | #1 |
Simple starter kill switch
What is the easiest way to install a kill switch for the starter solenoid to prevent theft? Can I just install a on/off toggle switch in line to cut power or ground?
01-11-2018, 02:50 PM | #2 |
Re: Simple starter kill switch
That is hard if you can't lock your hood or your steering wheel. No stater kill or battery disconnect will help on an old car. A couple jumper wires with alligator clips will get it started and running. I just take my coil wire with me if I am concerned where it is parked.
We used to do ignition or stater cuts that required you to pull the high beam switch or the right window switch up or cigarette lighter pushed in to activate the relay to allow the vehicle to be started. On an old car, a club or brake pedal to steering wheel lock would be more of a deterrent.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
01-11-2018, 03:03 PM | #3 |
Easier to put a switch inline with your coil power feed. It'll crank all day, won't get any spark. Thats what I did with my HEI.
I also have a battery kill switch, it's wired inline with the battery to engine ground. Switch off, nothing gets power anyways. Someone is going to have to figure out both to steal mine.
1970 GMC C2500, Vortec 406SBC, TH350
01-11-2018, 04:28 PM | #4 |
or switch the neutral safety switch.
personally I put 4 switches under the steering wheel.they are 3 position switches and not hidden, up-down-center. if first switch is moved up or down, horn and lights go off for 1 minute. 2nd switch brings power in, 3rd switch sends that power to HEI. 4th switch if for neutral safety switch. So basically you have to know the right combination. Trouble with a hidden switch is you want it somewhat easily accessible and they will look for that right way. this year I'm going to put a hood lock and alarm also. seems likes every old car show and suggested the high beam button so that no longer a secret. Fuel cut off strands them in the middle of the road close by for another option
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
01-11-2018, 04:42 PM | #5 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
I use one of these, http://www.spytecinc.com/sti-gl300-g...kaApFNEALw_wcB with one of these, https://www.sportsmansguide.com/prod...unds?a=1905120 Aint no thieves out here...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
01-11-2018, 04:59 PM | #6 | |
no subscription fee? Mark'
01-11-2018, 05:01 PM | #7 |
scratch that.. wiring kit cool
http://www.spytecinc.com/hard-wire-k...0-tracker.html
01-11-2018, 05:51 PM | #8 | |
01-11-2018, 05:52 PM | #9 | |
01-11-2018, 06:55 PM | #10 |
Keep an old iphone that is signed in with your apple ID in the truck with a power cable connected to charge it.
01-11-2018, 07:13 PM | #11 |
01-11-2018, 08:32 PM | #12 |
Does anyone know how the small GPS tracking devise for keys and such works? I think they are called TILES?
Jimmy Hoelzel |
