Installing new wood bed help?
I am installing a new wood bed in my 67 C10 fleet side. I need to know from you guys should I install the wood off the truck or is the only way to put the bed on the truck so you can put the cross sills in place then install the wood planks in strips?
Re: Installing new wood bed help?
I installed the cross sills first (loosely), then the wood and skid strips (loosely), then the head board (loosely), then one side at a time (loosely), then tightened everything up. Now, my bed was a conversion from metal to wood and it did NOT involve a kit, so my install would be different than typical. My main concern with assembling it off the truck was getting enough friends to pick the buggar up and move it without crinkling a lower bedside AND I really doubted that the holes that had to line up between the cross sills and the frame would magically line up after the bed was put into place leaving me to loosen everything up and fighting the alignment. Every one of the large cross sills were bolted to the frame and two of the smaller ones.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
I did mine on the truck. It was not too bad of a project, but there was one carriage bolt that I could not get to because of interference underneath, and a few others were a test of patience getting the nut started!
I would probably do it the same next time, unless it was for a full body off restoration. Jim |
![]() Join Date: May 2010
My bed was already off the truck. Therefore, I installed the wood, reinforcement strips and cross sills with the bed off the truck as suggested in the directions available from Mar-K. Once done, all that's necessary is to have some help lift the bed onto the frame and install the 8 bolts that secure it to the frame.
I built 4 heavy duty saw horses with carpeted 2"X6"s screwed to the top. I placed 2 of these crosswise under the front panel and 2 perpendicular to the rear cross sill. Last edited by FirstOwner69; 01-11-2018 at 01:15 PM. |
I did mine with bed on. it was home made and I wanted to be sure all bolts were accessible. its a pain crawling around under the truck but none of my bolts were in factory locations. it doesn't look factory but I spent les than $150 including new strips.
#6 | |
![]() Join Date: May 2012
http://67-72chevytrucks.com/vboard/s....php?p=7657989 j
White K20 |
Jeffahart, fantastic write up, I used that (and others) when I did my bed also!
Jim |
#8 | |
If you haven't put a finish on your wood yet, here's my quips on tung oil. http://67-72chevytrucks.com/vboard/s....php?p=7659407 j
White K20 |
I did mine with the bed on. Wasn't to bad. Just have a couple different extensions and swivel socket adapters. Had my wife hold the bolts down while I was under the bed starting all the bolts.
