Active Member
![]() Join Date: Mar 2009
While installing the radio I noticed that my accessory ignition switch function is not working. From what I understand, with these trucks, you should be able to listen to your radio, turn it on and listen to it when you turn your ignition switch to the accessory position. So why isn't working? Where does this wire runs? How do I fix it?
I would like to have an accessory function on my ignition switch. Thanks for your input. |
#2 | |
The Older Generation
Re: Ignition accesory function
All 1967 and some early '68's did not have an accessory position on the switch. The accessory terminal on the back of the switch was hot in the run position. Most '68's and all others after that had the accessory position.... LockDoc
Active Member
My truck is a 69
It should have an accessory position then. Did you try wiggling the key while you turn it to the left? If it still doesn't want to turn you will have to replace the switch if you want the accessory position to work.
LockDoc
Active Member
The key does turn to the accessory position, but the radio just doesn't work. Only works when truck is on. I must add that my truck cab is a 69 GMC.
![]() Join Date: Apr 2016
The radio is probably not plugged into the right place on the fuse panel, that is my guess. Check this out, post #5 may be of use, but the whole thread has some good info:
http://67-72chevytrucks.com/vboard/s...d.php?t=741245 |
Active Member
I had somebody help me when I started with this and forgot to check on that. It was plugged in the wrong place, radio works now the way I wanted it. Thank you!
Tags |
troubleshooting, wiring help |
