Old 01-14-2018, 06:32 PM   #1
Skunksmash
Skunksmash's Avatar
Do I have to replace power steering lines?
Got a new steering gear box from advanced auto. Instructions go on and on about replacing all the power steering hoses. Is this actually necessary? I'd really rather not have to buy all that and do all that.
Skunksmash is offline   Reply With Quote
Old 01-14-2018, 10:03 PM   #2
Bandit130
Bandit130's Avatar
Re: Do I have to replace power steering lines?
Depends on age and physical condition of hoses. If unsure of age, replace anyway. Better to have new hoses than to have one of them start leaking in the near future.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 01-14-2018, 11:21 PM   #3
Skunksmash
Skunksmash's Avatar
Yeah I went ahead and did it. Seems the pressure line was leaking, and the return line is just a hose.
Old 01-15-2018, 12:02 AM   #4
Bandit130
Bandit130's Avatar
I recently replaced mine. Thought they were original, but not sure. Just another thing not to worry about leaking.
Mopar by Birth
Chevy by Choice
Old 01-15-2018, 12:25 AM   #5
mongocanfly
mongocanfly's Avatar
I would replace as well..just for piece of mind
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-15-2018, 01:11 AM   #6
kwmech
The return line needs to be more than "just a hose". Pressure return line needs to be rated to 50 lbs (I think). Good time to put an inline filter on the return also.
Old 01-15-2018, 09:44 AM   #7
sweetk30
sweetk30's Avatar
the big big thing to do is flush out all the old fluid and bleed the system correctly then fire it up and check for leaks.
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-15-2018, 09:55 AM   #8
hatzie
Moderator
hatzie's Avatar
Agreed: The power steering return line needs to made of the right stuff. SAE J30R9 or J30R7 Fuel hose will not do the job even though the parts guy might tell you otherwise.
Hose that meets SAE J2076 is specifically engineered for power steering return hoses. Max oil temp 302°F and 175PSI running pressure.
You can use SAE J1019 transmission cooler hose. It's 250PSI and 302°F SAE minimum working spec exceeds Power steering return hose pressure specs. You'll find that several US manufacturers brag that their SAE J1019 Hose exceeds the minimum SAE specs. For instance some Gates J1019 hose is rated at 400PSI and 302°F.
More details in my post here: http://67-72chevytrucks.com/vboard/s...d.php?t=696742
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-15-2018, 12:01 PM   #9
Jstock85
I replaced mine as well. Hoses are cheap I think I got mine on rock auto. They were in pretty good shape but like other guys said Peace of mind really
Jstock85 is offline   Reply With Quote
Old 01-15-2018, 01:14 PM   #10
Malo83
Cruzzzn' Vet
Malo83's Avatar
Yup! change them, they could be deteriorating on the inside.
Malo83 is offline   Reply With Quote
Old 01-15-2018, 03:22 PM   #11
bennylava
bennylava's Avatar
Yeah I flushed out all the old fluid. I changed the pressure line with new from Advance Auto. The return line will have to wait for some other day. They gave me the wrong one at advance. Maybe I'll take it back and exchange it for the right one. The one they gave me had metal on both ends. One on the truck is just hose clamps on the ends. Nothing was leaking on it though, just on the pressure line which I did replace.
I wanted to go with a redhead steering gear, but I needed this done today so I just got a reman from Advance. Should be good enough. I'm sure it will be a world of difference from the worn out old one with 6 inches of play when you turn the steering wheel.
So in order to kill that play, I've now done the pitman arm, the steering gear, and the rag joint. What else is there that may cause play? The idler arm perhaps?
bennylava is offline   Reply With Quote
