Old 01-15-2018, 02:23 PM   #1
statenine
statenine's Avatar
what electric fans to use?
Hey all, I am in the process of swapping in a 2010 5.3 with 4L60E in my '66. What electric fan setup is everyone using? I am running a Champion aluminum 3-core radiator. I am leaning towards dual 11" Spal fans, but not sure how much clearance I will have once installed?
In particular I was looking at these because it has a built in shroud:
https://www.summitracing.com/parts/s...8aAthbEALw_wcB
This setup is just over 4" thick and I want to make sure it will clear the engine accessory drive? Thanks
statenine is offline   Reply With Quote
Old 01-15-2018, 05:58 PM   #2
dayj1
Re: what electric fans to use?
If you go with dual fans, you can "cheat" on the clearance a little because the 4" is measured at the fan motors which is the thickest part of the assembly and the part of the motor that is farthest forward is the water pump and is roughly in the center. In other words, the snout of the water pump can actually be further forward than the rear of the fan motors and you can stil have clearance.
Whether or not it will clear is dependent on exactly where you mount your engine. There are a lot of variables that will affect final placement.
The fan you linked will most likely work well. LS engines are not hard to cool. You could likely get by with much lower CFM.
dayj1 is offline   Reply With Quote
Old 01-15-2018, 06:10 PM   #3
mongocanfly
mongocanfly's Avatar
I think that's the same fan setup from summit I used on my 81 LS SWAP....it works great...ive got several inches of clearance... I was told to get the biggest cfm I could make fit...its probably overkill
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-15-2018, 06:15 PM   #4
statenine
statenine's Avatar
thanks guys. I've got the dirty dingo slider mounts which are adjustable so I know it will depend on final placement, it's just that 4" seems pretty thick so I wasn't sure how much room I would have. I'll wait until the motor is in before I order the fans so I can measure to be sure, I was just curious what others were using.
Old 01-15-2018, 07:32 PM   #5
GMC-YA68
GMC-YA68's Avatar
I bought the Entropy LSX radiator with fans for my 64. Made is easy, but not easy on the wallet.
I am also going dirty dingo. Which exhaust manifolds are you using / going to use?
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 01-15-2018, 07:34 PM   #6
statenine
statenine's Avatar
I went with the Speed Engineering shorty headers. I've been told by numerous people they are a perfect fit.
