Old 01-15-2018, 09:16 PM   #1
bjkttr
bjkttr's Avatar
Ccp spindles
Anyone running CPP modular dropped spindles(CP30106-4) ? I am interested in using them on my 65 c10. I was told they would work on my 65 all I have to do is swap out my ball joints. Is That true ?
bjkttr is offline   Reply With Quote
Old 01-16-2018, 02:54 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Ccp spindles
That part number is for '73-'87. It's not just changing the ball joints, you also have to change your whole steering to that year series too or have to use the adapter tie rod sleeves and your stock outer as the inner and the later model outer.
If you're ordering these, just get the right year ones. If you are picking them up used, make sure the cost of changing ball joints and steering stuff doesn't cost you more than just buying the right ones to start with.
As for using the modular spindles (of the correct year), I have used them on two '65 and a buddy used a set on his '68.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-16-2018, 04:16 PM   #3
mfm3
Re: Ccp spindles
I got these CPP modular spindles and caliper brackets from Summit. Using them with stock control arms on my 66 which is running discs from a 70's C10.
https://www.summitracing.com/parts/clp-cp30106-2
https://www.summitracing.com/parts/clp-6087dbk
mfm3 is offline   Reply With Quote
Old 01-18-2018, 01:08 AM   #4
rvrfoot
Re: Ccp spindles
I got all my stuff from cpp. I will post pictures on sunday.
rvrfoot is offline   Reply With Quote
Old 01-18-2018, 09:42 AM   #5
James903
Re: Ccp spindles
Ccp is a pain to deal with. If you know the part numbers just order their stuff from summit, and get free shipping.
James903 is offline   Reply With Quote
Old 01-18-2018, 01:05 PM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Ccp spindles
http://www.67-72chevytrucks.com/vboa...isc+brake+swap I did what Chevy Mike was talking about, but using my stock control arms and steering. I pretty much had most of the parts laying around from when I swapped the whole front steering into my other truck and used drop spindles. I kept the stock height ones for a rainy day.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 01-19-2018, 08:34 PM   #7
bjkttr
bjkttr's Avatar
Re: Ccp spindles
Thanks to everyone for the advice.
