Old 01-15-2018, 08:56 AM   #1
f66
f66's Avatar
F66 Custom Camper Build
Meet "Gross" my 1966 Custom Camper I bought in October 2016. The truck is called Gross because of the gross weight placards that came with the truck, and because the first words from my wife when she saw the truck was GROSS! LoL. So here is the story. I bought this truck to use as a daily driver and haul my 66 corvette. The inspiration comes from a picture of the trucks used to haul Roger Penske's race cars. My initial criteria was a C20 3/4 ton in good original shape, minimal rust, to use as a the starting point for the build. The truck came from Washington state, and the second owners son, who sold the truck after his dad passed. I feel very fortunate to have two build sheets and the SPID. (I have lot's of pictures in my profile.) I had the truck shipped to Maryland where I live, and started research and planning the build. My initial plan for the truck was a crate engine, driveline update, and brake update. After receiving the truck and looking at its originality and well preserved condition, I have decided to restore the truck and make updates that can be reversed if a future owner or i decide to go back to factory.
f66 is offline   Reply With Quote
Old 01-15-2018, 01:00 PM   #2
Bomp
Bomp's Avatar
Re: 66 Custom Camper Build
Congrats, Looking forward to the restoration.
Sub'd
Bomp is offline   Reply With Quote
Old 01-15-2018, 03:37 PM   #3
66C10LB
Looks good! Are you planning to keep the Saddle colour?
66C10LB is offline   Reply With Quote
Old 01-15-2018, 03:53 PM   #4
f66
f66's Avatar
Yes I am, I really like the color.
Old 01-15-2018, 04:03 PM   #5
Pontiacgurudan
That thing looks sweet!
Pontiacgurudan is offline   Reply With Quote
Old 01-15-2018, 05:18 PM   #6
f66
f66's Avatar
The first we did to start the project was initial clean up. Engine and anything around fluids was pretty gummed up. Power washed the engine bay and underneath so we could assess what needs to being done.
Old 01-15-2018, 06:16 PM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
Nice truck. It has everything else, does it have air?
Old 01-15-2018, 06:19 PM   #8
f66
f66's Avatar
Truck does not have air now and was not originally optioned. This is one option I am going to add.
Old 01-15-2018, 08:33 PM   #9
Robert Haas
The front sway bar is interesting, you know anything about it?
Robert Haas is offline   Reply With Quote
Old 01-15-2018, 08:35 PM   #10
shp4man
shp4man's Avatar
Man, that's a nice truck. No rust in the lower front fenders, must be some kind of miracle.
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 01-15-2018, 09:09 PM   #11
f66
f66's Avatar
I assumed the front sway bar/stabilizer was original. A front sway bar/stabilizer shows on the build sheet. What do you think?
Old 01-15-2018, 09:11 PM   #12
f66
f66's Avatar
Thanks, I am also very surprised there is no rust through. There is some minor paint bubbling on the lower fenders, but the truck is very very clean for age and era of truck.
Old 01-16-2018, 12:20 AM   #13
Captainfab
60-66 Nut
Front sway bars were available from the factory on the '63-'66 trucks both C10 and C20.
That is a very nice condition C20 with some nice options. I would also keep it mostly original. Hopefully it has 4.10 rear gears instead of the 4.57's
Old 01-16-2018, 01:14 PM   #14
sodly
sodly's Avatar
The front sway bar was part of the Camper Special package.
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 01-16-2018, 01:30 PM   #15
f66
f66's Avatar
Sodly, Thanks. BTW, I will be starting on the engine build soon, and posting that part of the project. I saw some of your early posts on 327 specs and questions. look forward to your input.
Old 01-16-2018, 08:14 PM   #16
f66
f66's Avatar
Just checked. Rear axle is JS (327 w/4:57) Will look for advice on best gears and trans options.
Old 01-17-2018, 01:14 AM   #17
Captainfab
60-66 Nut
The only other gears available for the Eaton HO52/72 is 4.11's. The only to obtain those is to find a good used 3rd member, and those are getting very difficult to find. Parts in general for those are getting harder to find and often times expensive. If this were my truck, I would change the differential for either a Dana 60 or a 10.5" 14 bolt. The other option would be to change the TH400 for a 700R4, 4L60E or a 4L80E. The differential would be the cheaper option. If you could find a Dana 60 from a '68-'72 big block C20, it would be a direct bolt in except for the panhard bar and if from an auto trans truck, it should have 3.54 gears. If you decide to go with a 14 bolt, I do make the trailing arm mounts for those. Here is a thread showing one member's conversion.
http://www.67-72chevytrucks.com/vboa...d.php?t=624445
Old 01-28-2018, 02:53 AM   #18
aotte1
Very nice Custom Camper, please keep us updated with pictures as you do your restoration. Photos of the original parts adds greatly to history on these trucks.
On the Easton HO52 rear axle, 4:11s and posi are more common in late 60s and early 70s with automatic transmissions. Have found some parts from these trucks, if you want to keep the HO52. If 4.11s works for you some searching should find them. Or as Captain referenced if you want 3: something gears.
Les
aotte1 is offline   Reply With Quote
Old 11-11-2023, 08:14 PM   #19
f66
f66's Avatar
As it happens to many of us, life gets in the way. I have been slowly working on rebuilding all of the drivetrain components, and the engine. Here is the progress.
U.S. Army Retired and Combat Veteran
Current serving DoD Civilian
1966 C20 Custom Camper Saddle 327 Automatic
1962 C1 Corvette Black/Fawn 327-300 4 spd
1966 C2 Corvette Silver/Black 327-350 4 spd
Old 11-11-2023, 08:34 PM   #20
Getter-Done
Getter-Done's Avatar
That is well Laid out Presentation and a Great step forward.
Nice Work .
The early bird gets the worm,
85 Chevy K-20
Old 11-12-2023, 10:45 PM   #21
f66
f66's Avatar
Here are the photos of the tear down.
Old 11-12-2023, 10:49 PM   #22
f66
f66's Avatar
More Tear down.
Old 11-12-2023, 10:54 PM   #23
f66
f66's Avatar
Clean Up of the drive train prior to rebuild.
Old 11-12-2023, 11:00 PM   #24
f66
f66's Avatar
Clean up and black oxide of the original fasteners.
Old 11-20-2023, 07:24 AM   #25
joesscamaro
Welcome back! Nice, clean & organized disassembly and reassembly!
joesscamaro is offline   Reply With Quote
