Old 01-17-2018, 09:38 AM   #1
gsharp
1" Rotors
I know that nobody sells the 1" thick rotors in 6 lug. I really don't want to change everything to go to a 6 lug 1-1/4 thick rotor. So my question is does anyone offer 1" rotors plug welded and drilled to 6 lug?
gsharp is offline   Reply With Quote
Old 01-17-2018, 10:09 AM   #2
Re: 1" Rotors
I may be lost on this, but are you using stuff from a newer vehicle, that you want to convert to 6 lug before you put it on yours?
I would imagine the plugging and redrilling would not be cheap, and you would be looking at doing it again whenever you need a new rotor.
Palf70Step is online now   Reply With Quote
Old 01-17-2018, 10:48 AM   #3
gsharp
Re: 1" Rotors
Thanks Bill.
Yes I already installed front crossmember from an 81. I put new calipers rotors brake lines and hoses. So kind of just wanted to change the rotors to a six lug. When I bought the crossmember I didn't know the difference between 1" and 1-1/4" I thought they were all the same.
Old 01-17-2018, 01:09 PM   #4
PGSigns
PGSigns's Avatar
Re: 1" Rotors
The rotors come with the hub and they can be plugged and redrilled. The machine shop cost may be higher than the parts to swap to 1 1/4" cost. Then you have to pay that each time you need rotors.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-17-2018, 01:12 PM   #5
Re: 1" Rotors
They are the same except for the caliper/rotor size.
I believe all the kits are made of the 71-72 disc brakes which were all 1 1/4. The 73-87 models came up with the lower end 1" thick ones.
Old 01-17-2018, 06:05 PM   #6
Warrens69GMC
Warrens69GMC's Avatar
Re: 1" Rotors
It would be less expensive (over time) to change the rear to 5 lug
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 01-17-2018, 06:44 PM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 1" Rotors
You could keep the 6 lug and use these (drilled is extra) - https://www.performanceonline.com/63...it-rear-6-lug/
My rear disc in five lug same system:
Old 01-17-2018, 07:35 PM   #8
gsharp
Re: 1" Rotors
Thank you.
Old 01-17-2018, 08:33 PM   #9
PGSigns
PGSigns's Avatar
Re: 1" Rotors
73 to87 came in both 1 1/4 and the light duty 1" rotors. When I bought my 66 I bought a crossmember out if a wrecked 80 model with dropped spindles in it. It had 1" rotors on it and 1 1/4 calipers. I put 1 1/4 rotors back on them in 6 lug. So it may be worth looking into swapping.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 01-18-2018, 01:11 AM   #10
rvrfoot
Re: 1" Rotors
I have cpp stuff i will see what size i have.
rvrfoot is offline   Reply With Quote
