01-17-2018, 02:48 PM | #1 |
SM465 Gear Oil Question
Hey guys, I'm going to change the gear oil in my SM465 trans and my NP205 t-case. I picked up 7 quarts of Valvoline High Performance 80W-90 gear oil. That's what I read that they took after doing a bit of research.
Anyway looking at the back of the bottle it says "Designed for use in non-synchronized manual transmissions where GL-5 is specified and for hypoid differentials where API GL-4 or GL-5 is specified." "Differential: API Service GL-4, GL-5 Non-Synchronized Manual Transmission: API Service GL-5" So can I use it in my SM465 since it is synchronized? Or should I pick up something else? Thanks
1978 GMC K25 1984 Chevy Scottsdale K10 built 350 4"lift - SOLD |
01-17-2018, 04:08 PM | #2 |
Re: SM465 Gear Oil Question
80-90 will work just fine
01-17-2018, 05:05 PM | #3 |
Well I talked to Valvoline and they said that it being GL-5 and hypoid it could corrode and damage the sychros in the trans so they recommended not using it. It is good to go in the t-case and differentials though, so I will use it for that.
So I'm going to pick up some 80W-90 GL-4 for the transmission just to be on the safe side.
01-17-2018, 06:26 PM | #4 |
The crap they write on containers is maddening! I have gone thru this with the petroleum manufacturing people & they swear it aint them doing it but the containers will be marked GL4 & GL5 compatible!
It's either GL5 for Hypoid gears or it's GL4 for transmissions! Here is a PDF Tutorial I had for you to save for future reference. It is from, of all places a Corvair Forum but read between the lines & the info will apply to our trucks as well as the lowly Corvair. But anyway rant over your on the right path! http://www.widman.biz/uploads/Transaxle_oil.pdf |
01-17-2018, 07:11 PM | #5 |
I topped off my 83 C20 SM465 about 16 years ago with Autozone 80/90 gear oil and have not done anything to it since. I am considering a drain and refill since the PTO covers are leaking a bit. So, I guess I will look for GL-4 for the fill up.
01-17-2018, 08:23 PM | #6 |
Thanks for the PDF, I saved it for future reference.
Yeah I was all ready to change the oils today and for some reason decided to read the back of the containers. The reason I bought it is because it said "meets or exceeds API Services GL-5 or GL-4", so I thought it was good to go. But on the back it says "For non-synchronized manual transmissions." Good thing I questioned it and did further research. Pretty confusing if you ask me, and should be a lot more straight forward to people who aren't in the know with oil types. I was pretty irritated about it, but at least I can still use it in my t-case and differentials. I'd also rather be irritated for a bit than ruining my transmission haha. I looked and called around local auto parts stores and nobody carries GL-4, so I ended up ordering Joe Gibbs Driven GL-4 gear oil safe for yellow metals and synchros. For future reference to those that need it, from what I can find for who makes GL-4 gear oil safe for our manual transmissions, (I'm sure they may be others) are these Coventional: Joe Gibbs Driven GL-4 Brad Penn PennGrade GL-4 Synthetic: Amsoil GL-4 Redline GL-4
01-18-2018, 02:41 PM | #7 |
NAPA usually carries GL4, FYI.
01-18-2018, 07:52 PM | #8 |
Moderator
Just look in the Maintenance and Lubrication section of the GM service manual for the GM recommended fluids...
From the 1987 Service Manual; 3-Speed (RPO M62 and M64) & 4-Speed (RPO M20) | SAE-80W GL-5 or SAE-80W-90 GL-5 gear lubricant GM part No. 1052271 (use SAE-80W GL-5 in Canada) **Edit** It's worth noting that even the 1973 Service Manual also calls for SAE 80 or SAE 90 GL-5 in the manual transmissions. The GM Engineers, being fairly conservative on things, apparently didn't trust multi-weight gear oils in 1972 when they put the 1973 manual together. They did call for the GL-5 rating straight through 1991 in the squarebody service manuals. The engineers at GM called for GL-5 in the SM465 and Saginaw 3 speeds in these trucks. We aren't talking about a pre-1993 VW/Porsche/Audi/Skoda/Seat or antique GM Corvair or some other vehicle that the MFG called for GL-4 in the transmission/transaxle. I would use what the MFG called for. The first half of this thread on Bob Is The Oil Guy about GL-4 & GL-5 oils is fairly informative... Page down to what Road Rage has to say for a distillation. Shortly after his post it devolves into off-topic religious arguments about what oil to use in more modern transmissions like the T56, NV3500, and NV4500 https://www.bobistheoilguy.com/forum...06251&page=all GL-5 oils from major petrochemical companies, at this late date, should no longer have active sulfur compounds. The folks on BITOG agree with homemade87. API MT-1 certification means you can be positive they are yellow metal safe. **Edit**
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 01-19-2018 at 01:10 PM. |
01-19-2018, 08:24 AM | #9 |
If it has this MT-1 listed on the back label its supposed to be fine for yellow metals . I have used the valvoline with the MT-1 in my muncies with no problem but since then I have used PennGrade Multipurpose Classic GL-4 Gear Oil 77296 .This is made specifically for brass or yellow metals .
Gl-4 in parts store is hard to fine since what they have is rated for both . I guess the dont stock it for a couple reasons . Double inventory and less demand . If using the dual rated just be sure it has the MT-1 listed on the back of the bottle . Last edited by homemade87; 01-19-2018 at 08:29 AM. |
01-20-2018, 01:10 AM | #10 | |
The info about MT 1 is good info, thanks. None of the petroleum engineers I have talked to in several years has mentioned this. Reason for being in contact with them is for the old T84 & T90 series Warner transmissions used in Jeeps. I typically find yellow oil & corroded sycros in these trans when broken down. Could very well be water contamination as well, or a combo. Last edited by andyh1956; 01-20-2018 at 01:16 AM. |
01-20-2018, 07:56 AM | #11 |
Moderator
The Corvair transmission was not a regular 4 speed Muncie transmission. It was a transaxle for an air cooled rear engine RWD vehicle that was designed and built in the early to mid 1960's. It has more in common with a VW Bus than a V8 RWD A-Body GM.
That being said I would use what the manufacturer said to use in it for oil. VW called for GL-4 in their manual transaxles at least through the late 1980's.
And please let us know if and how your repairs were successful. Last edited by hatzie; 01-20-2018 at 08:03 AM. |
01-20-2018, 10:03 PM | #12 |
Thanks guys. Lots of good info. So GL-5 MT-1 would be the correct oil? Good to know. I checked my Valvoline bottle and there is not MT-1 anywhere on it, so I'm still out of luck with that haha. But I will use it in the t-case and the diffs.
I did read on a few other forums when I was doing some research that people claim the have harder shifts using GL-5 in the SM465. They claim its too slippery for the sychros to work correctly. Others say they have used it with no problems. Seems like it can be a debatable topic haha.
01-20-2018, 11:03 PM | #13 | |
I have used the gears outta several of them before to repair the Muncies in my 55 & 57. Corvair transaxles could be had for scrap price, while a "Scrap" Muncie was still expensive! |
01-21-2018, 12:08 AM | #14 |
Moderator
They're worth a wee bit more now than they were in the 60's & 70's.
If the gears are cut the same direction as the 50's front engine transmissions then GM must've spun the Corvair engine "backwards". That's a piece of trivia I didn't know. I never had more than a passing acquaintance with the Corvair. In 1979 they were out of my price range and beginning to climb in value. I had four watercooled and one Air cooled VW along with a couple Datsuns and some GM and Chrysler station wagons and land yachts in the early 80s. None of them lasted long in the Northeastern salt.
And please let us know if and how your repairs were successful. |
01-22-2018, 11:57 PM | #15 |
One of my son's buds has a 66 Corvair w/ a v8 of some sort adapted to the transaxle & spun it around & now it's in the backseat! They race it on some kinda roadcourse racing where they set up the cones.
I asked him about the rotation of everything & he told me it has a marine starbord side camshaft that's cw rotation looking at the flywheel- I think I got that right- been a while since he told me that! (I think I coulda found something ez-er to hot rod on myself, like a truck!) |
