If you changed gear ratio in rear axle...wouldn't you have to change front too?
Stupid question but I just picked up a 71 K-10 and the guy said he had new 3.73 gears installed with posi but never said anything about up front.
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73 1972 C-10 Longbox,350/350 1998 Pontiac Grand Prix GTP FOR SALE: 1971 K-10 Longbox,350/SM465/NP205 Last edited by kickinasphalt; 04-26-2004 at 07:22 PM. |
you don't *have* to have the same ratio front and back for the truck to work in 2wd. also, if you drive off road exclusively, where the terrain is loose and will permit tires to slip, that would be ok in 4wd. however, if you put it in 4wd on pavement it won't be pretty. something will break, unless your tires can constantly break loose.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Maybe the old gears were also 3:73? I would want them to be the same, front & rear, no matter what.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Big Block Blazer
In order for 4 Wheel Drive to work, they Front and Rear Gear Ratio's must be the same.
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys] |
I agree with Adam. Pavement yes, in 2WD no and in the dirt no. You will notice the mud boggers run different ratios on purpose at times.
Talked to the previous owner last night and yes they had been changed.
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73 1972 C-10 Longbox,350/350 1998 Pontiac Grand Prix GTP FOR SALE: 1971 K-10 Longbox,350/SM465/NP205 |
