04-26-2004, 08:04 PM | #1 |
BANNED
Starter torque spec?
What should the starter be torqued at? SBC 350 Stock starter. Thanks
Chris |
04-27-2004, 08:16 AM | #2 |
35 on the starter
11 on the starter brace (full list below) Component Torque (ft/lbs) Bell Housing to Block 35 Carburetor to Intake Manifold 13 Choke Assy to Intake Manifold 8 Connecting Rods 35 Cylinder Heads 75 Distributor Hold Down 13 Exhaust Manifold to Cylinder Head 18 Fan Pulley to Harmonic Balancer 23 Fan Pulley to Water Pump 20 Flywheel Dust Cover 4 Flywheel/ Flexplate to Crankshaft 60 Fuel Pump to Timing Cover 20 Harmonic Balancer 120 Intake Manifold to Cylinder Head 55 Main Caps 95 Motor Mount to Block 63 Oil Drain Plug 30 Oil Filter 13 Oil Gallery Plugs 25 Oil Pan to Block 14 Oil Pick-Up Tube to block 8 Oil Pressure Regulator Retaining Nut 35 Oil Pressure Sending Unit to block 23 Oil Pump Cover to Timing Cover 10 Rocker Shaft to Cylinder Head 25 Spark Plugs 15 Starter to Block 35 Starter Brace to Block 11 Starter Brace to Starter 11 Thermostat Housing to Intake Manifold 20 Timing Chain Cover to block 29 Timing Chain Sprocket to Camshaft 48 Valve Cover Hold downs 4 Water Pump to Timing Cover 7 Windage Tray 11 |
04-27-2004, 08:05 PM | #3 |
BANNED
