Ordered from Western Chassis - received Chassis Tech?
Wanted to keep my 8 in ralley wheels, research showed Western Chassis would be best for 2.5 drop spindles. Summit kept pushing out ship date (for 3 months). Ordered from Western Chassis web site and received in 1 week. Spindles have "CHASSIS TECH" cast into them. I am familiar with reviews on Chassis Tech. Is this normal for Western Chassis to make this substitute? It would seem that most of the problems with the spindles are from 10 yrs ago. My first inclination is to send these back to Western. Thoughts?
87 Silverado 5.3/4L60E 3.42 91 Silverado 4X4 350/700R4 88 Silverado CrewCab Dually 454/TH400 - sold 81 Camaro 350/4 speed ROC (ruff old car) 02 Camaro SS LS1/T56 13 Dodge Charger Hemi (state surplus patrol car) |
Diggin The SquareLife
Re: Ordered from Western Chassis - received Chassis Tech?
I would send them back. its should say western on them
Western Chassis is now owned by POL.
POL might have substituted Chassis Tech spindles (they wanted to on my order).
Since they (Western Chassis) messed up on another portion of my order from the beginning I was in contact w/them. As they were sorting through their error & got that corrected he mentioned there was also a back order issue for my selected spindles & a substitution was required to complete my order. I inquired what mfr. spindles I would be getting (he didn't know). When he got back on the phone he said CT's. I cancelled my order. Not sure what would have happened had they not made an error in the first portion of the transaction & I contacted them (they might have just shipped the 'substitute' spindles).
67-72 parts collector,…
![]() Join Date: Nov 2002
Send them back.
Buy Belltech, McGaughy's, or EarlyClassic spindles. Glad this info is getting out about POL (Performance Online) and Western Chassis.
I contacted Western yesterday and after explaining the situation, was told the Chassis Tech "would carry the same warranty". I advised that the reason I ordered Western was because I wanted to use my rally wheels and everyone with experience found that no mods to lower control arms was needed and that Western had excellent reputation but Chassis Tech not so good. So the rep asked if he could call back after some investigation.
So later in the day, Rick called and advised "there had been a problem with some of the castings" and that was the reason for the substitution. Also it was unknown what the delivery date would be on the Western spindles so I told him I wanted Westerns, I had no confidence in the Chassis Techs and I would send them back and Rick gave me the 'RGA' number. Just to be clear, I don't want to hurt Westerns reputation. The spindles I ordered were for 81-87 Chev C10 with 1" rotors. I have no knowledge of any other items. Thanks for the replies. I will try another one of the 'top' brands.
#7 | |
On top of that, I googled Chassis Tech spindles & by making this substitution, they're making more $$ on the sale since they retail for a lower initial cost (if you search around). IMHO, that is not good business practices. If you make a substitution, the purchaser should be notified before the transaction is approved.
Belltech 3200 spindles work with the 1" rotors.
Also I'm not sure about your info concerning rally wheels working or not. It all depends on the wheel diameter and backspacing.
15x7 truck rallys have a 3-5/8" bs.
No issue. 15x6.5 and 15x8 truck rallys have a 4" bs and may require trimming of the lower a-arms around the ball joint. This is a known issue. A lot of aftermarket rally wheels only have a 3-1/2" backspace. You have to compare apples to apples when you are talking wheels and spindles working together.
#10 | |
Belltech may be a little more expensive ($311) but most places like Summit Racing offer free shipping.
They also come coated, where others are shipped in bare metal.
Not sure all Belltechs come coated. The ones I ordered for my 99 (that had the casting number discrepancy) were bare.
#13 | |
But that’s been a while.
#14 | |
Went to the new Arlington location to exchange them because the Belltech online REP said the number didn't match but it should so it was probably mix-boxed. At the exchange visit, the 2 other boxes Summit pulled were both the same (& sure looked 'as cast' to me). Seems I'll be doing it all over again. I had to go back to the Belltech line a second time & that REP said the initial casting is one p/n. Then, if machined further, they get a different p/n ( they were p/n 3700 on the box; 3600 casting number on each spindle). IDK @ this point. But, given my described WC experience above this week, I'll be purchasing another pair of Belltechs from Summit again.
#15 |
![]() Join Date: Jul 2000
My 2.5" drop Western Chassis spindles for 1.25" rotors clear my GM 8" Rally wheels. To the person who said that just about any spindle clears 7" Rallys, that's true, but good luck finding a set of those wheels.
For what it's worth, when I was doing my search on dropped spindles, a McGaughy's guy told me his wouldn't clear my wheels. If he was wrong, well that's a good thing, I guess. About POL/Western, I have to say I've had top notch customer service from them. The sway bar I bought from them had a problem, and after asking for photos they offered to send me another one the next day! And none of this crap about I must be doing something wrong, etc., etc., or that they have to charge my credit card, then issue credit when I return the first bar. I will definitely buy from them in the future.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#16 | |
That's like paying for the nicer features you want on a 'loaded' truck & then get a stripped down version when it arrives (w/o them telling you they're sending you something different).
#17 |
![]() ![]() Join Date: May 2015
another spindle thread.....makes you wonder what's going on...
http://67-72chevytrucks.com/vboard/s...d.php?t=755491
#18 |
![]() Join Date: Aug 2014
I ordered Western chassis spindles from summit few weeks ago for my square and mine were western chassis brand when arrived.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
#19 | |
For the OP (whitelightning603), it might be worth checking to see if Summit has what he needs & compare pricing.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-31-2018 at 10:31 AM. |
#20 |
We sell the BellTech spindles... well their complete line.
Spindles for 73-87: http://www.azproperformance.com/Bell...3100-3200.html |
#21 |
Just Google Performance Online complaints.
#22 |
FYI, Summit will match any advertised price. I've done that several times over the years, most recently with a pair of Raybestos rotors. They matched Rock Auto's total price including Rock Auto's shipping charge.
#23 |
I'll have to check into that then.
#24 |
Just found them on YELP. Yes, not very good reviews. But heck, even Summit Racing gets only 3.5 stars, same as POL. And Summit is probably the best performance parts company I've ever dealt with -- for more than 25 years now. So maybe what we're seeing is this: Customers with problems are more likely to post reviews than happy customers.
#25 | |
