Make your doors close like a Mercedes in 60 seconds
Remove the door seals!
If this doesn't help you can start looking at hinges, striker bushings, strikers, etc. But if they suddenly close like a dream, then how can this be fixed? -new door seals may be softer and more pliable- usually makes it worse as the re-pop seals appear to be fatter and never seem to "wear in" as anticipated -Honda Civic or Dodge Dakota seals- haven't tried this yet -Carving away some of the seal at the hinge pillar where the binding usually occurs-might help but will likely look like dog sh$t -adjust the hinges so the doors stick out - there's a great idea -Punch holes in the hollow bulb portion to let air escape- anyone try this? -Maybe your doors were previously adjusted to eliminate wind noise- Back in the day when these trucks were new, customers often complained about wind noise at the top and windshield pillar and GM would bend the top of the door inward and advise the customer the wind noise is gone but the door will need a good slam now- I guess if that's the area of if resistance you need to bend the window frames back to where they belong -Just learn to accept you are driving a Chevy square body and your insurance is a lot less than a Mercedes |
Re: Make your doors close like a Mercedes in 60 seconds
Umm...ok
Or, you know, fix them.......properly.
![]() Join Date: Oct 2014
I don't know if I would do all that, I did replace the all the door rubber and cab seal. But the main reason why the doors are hard to close, is because the bushing is no longer on the striker. Replace this and the doors WILL close like they used to when they where new.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
I've already replaced the striker bushings, and the strikers, and the hinge pins, but my problem is the door seals. They create resistance and you have to slam the doors to overcome that resistance. Even with the striker removed you still have to push the doors with considerable force before they fit flush.
#6 | |
Buy a Mercedes, these are old trucks and are supposed to be noisy!!!
Take Care Troy |
#8 | |
Moderator
![]() Join Date: Oct 2008
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Yep,, I have seen that
#10 | |
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! ![]() 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
I have to slam mine so hard,, because it's to air tight.
I used a 3/4" long piece of 1/2" PEX on both my 86 and my 77.
They close like new now. Took about 5 min for each door.
77 Chevy K20 Longbed 86 GMC C3500 Dually 07 Silverado 2500HD All standard cabs |
pex worked on my 77
#15 |
![]() ![]() Join Date: May 2015
here ya go 85/s....https://m.youtube.com/watch?v=yS_eRtSdw-A
#16 |
Replace the strikers
#17 |
Cracking a window helps mine close really nice and smooth. Hard to believe a 42 year old non restored truck can still be that airtight.
#18 |
I agree, the PEX might be a temporary fix but, it looks kinda like a trailer park repair (sorry for the reference, I am from Florida). I foresee that PEX finding its way to spinning around and jamming up in the door. Likely at the worst time possible. Just replace the strikers and you are good.
#19 |
Couldn't believe the difference it made with new strikers and bushings. Much better and close so easy
#20 |
They didn't close that great even when new, because (in addition to all the stuff mentioned above: seals, hinges, strikers, etc) there is not a lot of mass in the door itself.
You can't generate enough momentum to just swing it and walk away. You will probably always have to press firmly until it is fully closed (I usually leave my hand on the outside door handle and ride it all the way closed). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#21 |
Precision brand door seals are preferred by body shops. Don't buy any door seals or any other rubber or felts from Ebay or Amazon - that was my mistake.
