Old 01-30-2018, 12:51 PM   #1
stanski
Make your doors close like a Mercedes in 60 seconds
Remove the door seals!
If this doesn't help you can start looking at hinges, striker bushings, strikers, etc. But if they suddenly close like a dream, then how can this be fixed?
-new door seals may be softer and more pliable- usually makes it worse as the re-pop seals appear to be fatter and never seem to "wear in" as anticipated
-Honda Civic or Dodge Dakota seals- haven't tried this yet
-Carving away some of the seal at the hinge pillar where the binding usually occurs-might help but will likely look like dog sh$t
-adjust the hinges so the doors stick out - there's a great idea
-Punch holes in the hollow bulb portion to let air escape- anyone try this?
-Maybe your doors were previously adjusted to eliminate wind noise- Back in the day when these trucks were new, customers often complained about wind noise at the top and windshield pillar and GM would bend the top of the door inward and advise the customer the wind noise is gone but the door will need a good slam now- I guess if that's the area of if resistance you need to bend the window frames back to where they belong
-Just learn to accept you are driving a Chevy square body and your insurance is a lot less than a Mercedes
stanski is offline   Reply With Quote
Old 01-30-2018, 12:59 PM   #2
SunSoaked
SunSoaked's Avatar
Re: Make your doors close like a Mercedes in 60 seconds
Umm...ok
SunSoaked is offline   Reply With Quote
Old 01-30-2018, 03:30 PM   #3
RotaryRocketeer
RotaryRocketeer's Avatar
Or, you know, fix them.......properly.
RotaryRocketeer is offline   Reply With Quote
Old 01-30-2018, 05:16 PM   #4
TKCR
TKCR's Avatar
I don't know if I would do all that, I did replace the all the door rubber and cab seal. But the main reason why the doors are hard to close, is because the bushing is no longer on the striker. Replace this and the doors WILL close like they used to when they where new.
Old 01-30-2018, 06:10 PM   #5
stanski
I've already replaced the striker bushings, and the strikers, and the hinge pins, but my problem is the door seals. They create resistance and you have to slam the doors to overcome that resistance. Even with the striker removed you still have to push the doors with considerable force before they fit flush.
Old 01-30-2018, 06:52 PM   #6
TKCR
TKCR's Avatar
If they are new seals, then you'll have to leave your doors shut for awhile. They will press down, to were they are creating that resistance. That's what I did with mine. Also, open your vent windows or crack your window. Close your door now and see if that helps.
Old 01-30-2018, 07:24 PM   #7
Troy Sr
Troy Sr's Avatar
Buy a Mercedes, these are old trucks and are supposed to be noisy!!!
Take Care
Troy
Troy Sr is offline   Reply With Quote
Old 01-30-2018, 07:39 PM   #8
hatzie
Moderator
hatzie's Avatar
There are folks using PEX tube in place of that bushing.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 01-30-2018, 07:51 PM   #9
TKCR
TKCR's Avatar
Yep,, I have seen that
Old 01-30-2018, 09:56 PM   #10
808_67C10
808_67C10's Avatar
Amen
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 01-30-2018, 10:42 PM   #11
85/Silverado
85/Silverado's Avatar
I have to slam mine so hard,, because it's to air tight.
85/Silverado is offline   Reply With Quote
Old 01-31-2018, 05:27 AM   #12
Man With A Gun
Man With A Gun's Avatar
I used a 3/4" long piece of 1/2" PEX on both my 86 and my 77.
They close like new now. Took about 5 min for each door.
77 Chevy K20 Longbed
86 GMC C3500 Dually
07 Silverado 2500HD
All standard cabs
Man With A Gun is offline   Reply With Quote
Old 01-31-2018, 08:13 AM   #13
85/Silverado
Someone have a photo of what your talking about?
Old 01-31-2018, 08:18 AM   #14
lowbucktrucks
pex worked on my 77
lowbucktrucks is offline   Reply With Quote
Old 01-31-2018, 08:27 AM   #15
mongocanfly
mongocanfly's Avatar
here ya go 85/s....https://m.youtube.com/watch?v=yS_eRtSdw-A
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
mongocanfly is online now   Reply With Quote
Old 01-31-2018, 09:57 AM   #16
jkk
jkk's Avatar
Replace the strikers
jkk is offline   Reply With Quote
Old 01-31-2018, 11:26 AM   #17
RotaryRocketeer
Cracking a window helps mine close really nice and smooth. Hard to believe a 42 year old non restored truck can still be that airtight.
Old 01-31-2018, 11:29 AM   #18
808_67C10
808_67C10's Avatar
I agree, the PEX might be a temporary fix but, it looks kinda like a trailer park repair (sorry for the reference, I am from Florida). I foresee that PEX finding its way to spinning around and jamming up in the door. Likely at the worst time possible. Just replace the strikers and you are good.
Old 01-31-2018, 01:26 PM   #19
GMDad
GMDad's Avatar
Couldn't believe the difference it made with new strikers and bushings. Much better and close so easy
GMDad is offline   Reply With Quote
Old 01-31-2018, 01:50 PM   #20
Keith Seymore
Keith Seymore's Avatar
They didn't close that great even when new, because (in addition to all the stuff mentioned above: seals, hinges, strikers, etc) there is not a lot of mass in the door itself.
You can't generate enough momentum to just swing it and walk away. You will probably always have to press firmly until it is fully closed (I usually leave my hand on the outside door handle and ride it all the way closed).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-01-2018, 11:51 AM   #21
tucsonjwt
Precision brand door seals are preferred by body shops. Don't buy any door seals or any other rubber or felts from Ebay or Amazon - that was my mistake.
tucsonjwt is offline   Reply With Quote
