Old 01-31-2018, 04:41 PM   #1
SabbathFanatic
SabbathFanatic's Avatar
In-tank pump with 87 blazer tank/sender wiring
So I just got in all the parts I need to plumb my fuel with the 31 gal blazer tank.
GM14C tank
FG12L sending unit
EP381 pump
I think I've seen a couple of times that the pump wiring on the sending unit needs to be beefed up a little for reliability. What gauge does it need to be replaced with?
Also, never done anything with a fuel pump before, so wondering if there are any good tutorials or build threads with pictures for putting together the pump on the sending unit. It looks pretty straight forward, but I want to make sure I don't miss anything.
Thanks in advance!
1971 C10 - LQ4/4L80E swap in progress
1988 K3500 - 8.1 swap planned
SabbathFanatic is offline   Reply With Quote
Old 01-31-2018, 05:09 PM   #2
GMC-YA68
GMC-YA68's Avatar
Re: In-tank pump with 87 blazer tank/sender wiring
you can't mess that up. It's a no brainer. The wiring on that pump with plug right into the connector on that sending unit.
Only problem I had was the fuel sender was bad right out of the box when I installed it. Luckily I didn't have the body back on it yet. I'd try to temporarily hook it up to your gauges to make sure it's working before you put it all in.
I didn't mess with the wiring on mine.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 01-31-2018, 05:16 PM   #3
SabbathFanatic
Yeah, I was more wondering about all the clamps and sleeves and strainer basket and stuff. I'm sure I can find a picture and figure it out.
Old 01-31-2018, 09:27 PM   #4
ls1nova71
ls1nova71's Avatar
HAHA! You should never forget the strength of stupid people! There's a guy at work who forced the wiring plug on one backwards a few weeks ago, and it turns out that if you put 12v straight to the fuel level sender it burns it up straight away! Then you're left wondering why the fuel gauge doesn't work, and it cant be the sender because its new..... Replace gauge. .. Still dont work..... Remove sender and find the idiots handy work!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-06-2018, 01:26 AM   #5
GMC-YA68
GMC-YA68's Avatar
I’d quit, or fire him. Isn’t that some workplace violation...? I’ll take his money if he wants to keep giving it away!
As always thanks for all your help Eric. You da man with these swaps!
-Keegan-
Old 02-06-2018, 01:38 AM   #6
SabbathFanatic
For anyone finding this post in the future, I figured it out no problem and the part numbers I listed fit together perfectly. Pic included.
Old 02-06-2018, 11:58 AM   #7
GMC-YA68
GMC-YA68's Avatar
What is your plan as far as a fuel fill? Don't you want it turned the other way?
-Keegan-
Old 02-06-2018, 12:20 PM   #8
SabbathFanatic
I'm going to cut the passenger side filler out of a square body and weld it in.
I would prefer a driver side filler, but the driver's side of the bed is original paint with awesome patina and the passenger side is already all primer. I'd rather keep as much original paint as possible, so I'll deal with the passenger side filler.
