Old 01-29-2018, 10:41 AM   #1
rockosocko
'01 NV4500 in a '95 2500 5spd compatibility ?'s
I have a '95 2500 2wd and found another NV4500 2wd at the pull it from a '01 2500
BUT this one has a Hydro collar and two lines for the T/O bearing, whereas
my '95 only has the external slave to push on the fork.
Will the '01 swap and will I be able to just swap out my slave, fork and bell housing.
OR will I have to fab up all sorts of stuff to make it work?
My orig is leaking pretty badly and not sure how much fluid is actually left since I flushed it last..
This '01 looks to have been rebuilt/taken apart at some point since it was pretty clean, just a bit dusty-dirty and not oil soaked dirty..
I know the shifter tower is different, but don't think that will be any problem like the T/O might be..
rockosocko is offline   Reply With Quote
Old 01-29-2018, 11:47 AM   #2
b454rat
Re: '01 NV4500 in a '95 2500 5spd compatibility ?'s
I know 95 is a bastard year, I wanna say it shares the bell to tranny bolt pattern but uses 96-up gears.
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 01-31-2018, 01:01 PM   #3
rockosocko
Hhhmmm.. Never heard of a "bastard" year. Just higher granny gear (1st) than the later.
From like 6.34 up to 5.61 in '94ish.
I just know that my truck feels like it's a 3spd with VERY steep Granny 1st and a nice Overdrive 5th on either side..
Anywho, Just need to know if I can swap my throw-out bearing assy to the later "tower" style NV4500, and not be forced to use another hydraulic set-up.
Old 01-31-2018, 01:13 PM   #4
b454rat
Think there are three versions of the 4500. Steep first gear, 92-95 I think, then 96-up. But I’d think hydro off whatever bell you have would work. Don’t think there is a difference on the tranny side of it.
Old 01-31-2018, 03:13 PM   #5
rockosocko
that's what Im hoping. Just a mess under there and my steam cleaner is down right now.
Don't want to drop a slippery 200lb tranny on me.
I contacted Advanced Adapters with no response yet. But hey, I can wait a few days.
Old 01-31-2018, 03:49 PM   #6
Richard2112
Richard2112's Avatar
I and some other members here have bolted a cast iron BH to the NV and run them without the problems associated with hydraulic assist. I'm willing to push the pedal a little harder in exchange for less and easier maintenance.
Richard2112 is offline   Reply With Quote
Old 02-01-2018, 09:56 AM   #7
SunSoaked
SunSoaked's Avatar
I wouldn't call it "assist", it's either mechanical linkage or hydraulic. The juice setup has advantages. Either one just needs setup correctly.
SunSoaked is offline   Reply With Quote
