Old 02-02-2018, 12:20 AM   #1
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
71 blazer heater/defrost box
Anyone seen a box like this? The left side looks different than any I have seen before...
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 02-02-2018, 09:48 AM   #2
hemi43
hemi43's Avatar
Re: 71 blazer heater/defrost box
Looks like "heater delete" option.
hemi43 is offline   Reply With Quote
Old 02-02-2018, 01:22 PM   #3
chevyguy_72
Vintage Evil
There is a flapper inside of that box and a slot cut in the bottom and each corner... You can kinda see them in the pics...
Current Rides:
Old 02-02-2018, 11:25 PM   #4
hemi43
hemi43's Avatar
Yeah, but there's no fan. Even with heater delete, laws back then still required some sort of defrost. Even vehicles with heater delete, will still have a heater core. Not sure how GM did it, but I'm familiar with Mopars of the 60's
Old 02-05-2018, 12:29 PM   #5
chevyguy_72
Vintage Evil
Theres not a fan under there either way...
The fan is on the firewall next to the heater core...
The only thing under there is the box with all the flappers.
Current Rides:
Old 02-05-2018, 12:58 PM   #6
GMC-YA68
GMC-YA68's Avatar
Yea, but if you put a fan on the firewall, then turned it on...where is it going to blow? - not in that box because it's not connected to it in any way.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 02-05-2018, 06:16 PM   #7
chevyguy_72
Vintage Evil
Not sure what you mean here?
This has the same engine bay heater core/fan unit... i was just showing the first pic to show that its a non AC unit...
The stock located fan will blow through the heater core and into the cab portion of the heater box... my only question is the reason for the different shaped unit that disperses the heater and defrost.
Current Rides:
Old 02-05-2018, 06:50 PM   #8
hemi43
hemi43's Avatar
Like I mentioned before, most likely it had "heater delete" option.
Old 02-06-2018, 12:08 PM   #9
chevyguy_72
Vintage Evil
Sorry but that doesn't make sense to me since it actually has heater ports on the bottom and sides? A delete to me would be no heater at all... maybe just a defrost unit... this still has both and a flapper inside to control between them with all 3 wires and the same controls as the other unit...
Current Rides:
Old 02-06-2018, 01:46 PM   #10
cleszkie
cleszkie's Avatar
Whatever you have there apparently did not come with that truck because I can see the mounting holes where the original box was mounted. Are there provisions for a heater core inside the box, or any sign of openings that heater hose could have been routed into? Otherwise that box is pretty much worthless as a defrost without a fan, and worthless as a heater without a fan and source of heat.
cleszkie is offline   Reply With Quote
Old 02-06-2018, 05:14 PM   #11
chevyguy_72
Vintage Evil
The stock engine compartment unit is there and ready to bolted on... it contains the heater core and fan is identical to every non ac one i have ever seen in these trucks... the only different part is the air deflector portion that directs air to the defrots vents or the floor...
Current Rides:
