Old 02-04-2018, 10:19 PM   #76
Erics51chevy
Re: 51 chevy build
Made a new engine crossmember. Bought polyurethane bushings.
[IMG][/IMG]
[IMG][/IMG]
Welded the spring perches on and painted the rear
[IMG][/IMG]
Erics51chevy is offline   Reply With Quote
Old 02-06-2018, 09:18 PM   #77
Erics51chevy
Re: 51 chevy build
Picked a color that i feel is a nice 50 60s accent color. And because i said why not
[IMG][/IMG]
[IMG][/IMG]
Old 02-11-2018, 11:41 PM   #78
Erics51chevy
Re: 51 chevy build
Used valspar varnish to seal the wood for the bed.
[IMG][/IMG]
Lifted the cab to start boxing the frame and reinforcing it.
[IMG][/IMG]
First plate for trans crossmember
Anybody know of a good main harness connecter at the firewall so i can unplug all the wires and once and lift the cab?
Old 02-12-2018, 03:18 PM   #79
Mains52
Re: 51 chevy build
Are you keeping the camaro wheels on there? I’m really wanting to do the camaro wheels on mine but haven’t seen too many with them. Nice fab work so far!
Mains52 is offline   Reply With Quote
Old 02-12-2018, 06:25 PM   #80
Erics51chevy
Re: 51 chevy build
They are actually wheels off of my nissan 350z. But they do look very similar. I was looking for a set of camaro or z06 wheels. They look nice and are beefy. I might need to do mini tubs.
Old 02-18-2018, 08:38 PM   #81
Erics51chevy
Re: 51 chevy build
Finished and painted trans crossmember. Engine angle is 4.2 degrees down. Rear is 4.2 up
[IMG][/IMG]
Finished the rear boxing plates. Left the fuel lines inside the frame for the back half of the truck. Ran out of welding wire after tacking the middle plates.
[IMG][/IMG]
[IMG][/IMG]
Takes long to weld up.
Old 02-25-2018, 02:02 PM   #82
Erics51chevy
Re: 51 chevy build
Finished welding the boxing plates.
Made a gas tank cage super tight. And 2 straps to hold it down. The two bulkhead fittings were leaking in the bottom of the tank so i had to drain the tank and reach inside through all of the foam and impossibly get a wrench on it. Made a mess of gass.
[IMG][/IMG]
