02-06-2018, 12:25 PM | #1 |
motor exploder
parking brake assembly
Working parking/emergency brake pedal assembly taken out of a 1969 C10. What you see is what you get, mounting studs are good and so are the cable adjuster threads - includes deluxe pedal pad. First "I'll take it" gets it. $60 shipped.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
02-22-2018, 04:04 PM | #2 |
Active Member
Re: parking brake assembly
if its the same as a 68 ill take it
thanks Bryan |
02-22-2018, 04:25 PM | #3 |
FYI 67-68 have a pull handle located under the steering column
02-22-2018, 04:29 PM | #4 |
Active Member
thanks for the info. this is the first truck that i am restoring. i bought it in pieces but there are a lot of things missing. ill keep looking
thanks Bryan |
Tags |
e-brake, ebrake, emergency brake, parking brake |
