![]() Join Date: Sep 2012
Looking for a 1968 and up Muncie M22
Looking for a 1968 or up Muncie M22,must be a M22.Don't need shifter for it just the transmission.
Thanks Brian
1971 c10 custom deluxe fleetside swb LS3 w/BTR stage IV cam,4L85E w/3600 stall 67-72chevytrucks.com/vboard/showthread.php?t=558024 |
![]() Join Date: Jan 2004
Re: Looking for a 1968 and up Muncie M22
What are rock crushers going for these days ?
There all over the place but a good rebuilt one could be 1,100-1,300.If they need rebuilt can get expensive if it needs gears.Also the 26 fine spline onse are more desirable.
I do not know what it is exactly, but a friend has a Muncie in his garage. I saw it, but I know nothing about them. You may have to help me identify it.
I will try to take pictures of it and post it here.
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
Yeah there are a few ways to identify them,just try to take pics of all numbers you see there are numbers in 3 to 4 different places.Also take a few pics of input shaft.
#6 | |
Will try to get there tomorrow. It is in the rafters above his garage. Will be a challenge but I'll get up there somehow. Bill
The price can depend on what vehicle the numbers go to. The one for my '67 is correct for a '65 GTO, so could bring bigger money to someone who has to have it for their high dollar car
Pretty sure Pontiac didn't offer an M22 in a 1965 GTO not even as an option. M20 or M21.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
![]() Join Date: Nov 2012
All M22 had straight cut gears. Used only on GM Hi Performance cars
Roger Koop |
You can buy a brand new super case M22 for $2400. Unless you are really fortunate, a 50 year old 4 speed is more than likely going to need some work. You can also find some that have been professionally rebuilt, but they aren't cheap either.
https://www.midwestmuncie.com/produc...-rock-crusher/ They also offer rebuilt units but you have to have a core or there is a $500 core charge https://www.midwesttrans.com/M21,%20...nsmission.html
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 Last edited by rsavage; 02-10-2018 at 08:20 AM. |
$2400.00? That to the uneducated Muncie person like myself seems pretty steep. I guess if that is what you must have then it is it.
Friend was out shopping for hand cannons this morning so I was unable to get over there. Will try for Monday morning.
![]() Join Date: Jan 2018
Here you go. Not mine, but 45 minutes away. If your interested I can go look at it for you. Came out of a 68 Chevelle.
https://lincoln.craigslist.org/pts/d...451528215.html |
![]() Join Date: Dec 2015
There's a guy that my Dad has bought several rebuilt M20s and M21s from. Came across him at swap meets. I believe he's in Pensacola. At the swap meet last week he had a couple M-22s. His name is Matthew 954-985-0264.
#15 |
![]() Join Date: Dec 2013
What bell housing are you planning on using ? The out put hole of the bell housing must match the trans , The '67 stock bell housings work the later bell housings have a larger output hole which results with the car muncie's relying only on the 4 bolts and can crack the muncie mounts .
#16 | |
Ron https://www.summitracing.com/parts/add-716078
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
#17 |
Still have not climbed up in the garage rafters however, I was told it came out of a 66 GTO 389 Tri-Power. If that helps at all.
Obviously the casting numbers will tell the truth 100% when I get them. Bill
#18 |
A 66 GTO came with either the M20 or M21.
#19 |
I saw that online but memories do fail and my friend is in his 70's...
