Old 12-31-2017, 02:51 PM   #1
panhead59
windshield sealent ?
It seems that a lot of us have trouble getting windshields not to leak. I will be installing mine soon and don't want to do it twice, or more, because it leaks. After 50 years or so, the lip that is central to it all is rarely "perfect". So is there a sealent or some other "trick" that could aid in this? My 66 GTO uses a 5/16 "ribbon sealent" and a "window weld resealent" for the windshield, made by 3M. Would/could these be appropiate for our 67-72 trucks or are we stuck with trusting a new rubber mounting strip and a prayer? Or maybe just pay a glass shop to do it and make sure they guarantee it not to leak!!!!!
panhead59 is offline   Reply With Quote
Old 12-31-2017, 05:11 PM   #2
70cst
70cst's Avatar
Re: windshield sealent ?
Maybe this might be of help ...
To seal or not to seal, that is the question?
http://67-72chevytrucks.com/vboard/s...d.php?t=413711
Windshield Install Adhesive or no
http://67-72chevytrucks.com/vboard/s...d.php?t=742655
Windshield gasket blues: Precision supplies Steele and possibly Soft Seal
http://67-72chevytrucks.com/vboard/s...d.php?t=484773
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-01-2018, 12:16 AM   #3
truckster
truckster's Avatar
Make sure that if you use a sealant it's a flow-grade butyl rubber. That's the correct sealant for rubber gaskets. Many manufacturers used urethane sealant around the early 80s as they transitioned to urethane-set windshields, but that was a stopgap measure intended to meet newer structural requirements and isn't necessary for our trucks, and will likely mean your new gasket will be destroyed the next time you replace your windshield.
Your GTO doesn't use a rubber gasket. The glass is glued to the pinchweld with the ribbon sealer, which is a heavier butyl rubber. It's a different type of installation.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 01-01-2018, 07:46 AM   #4
GMCPaul
The Factory service manuals in the body section tells you to Use sealant along with the seal during install to prevent leaking so the answer is of course use sealant.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 01-01-2018, 08:24 AM   #5
panhead59
Thanks for the replies
Old 01-01-2018, 01:48 PM   #6
truckster
truckster's Avatar
GMCPaul
It's been a while since I took a look at it, but I believe it specifies 6 or 8 inches at the top corners. Having been in the glass business for years, I found that they rarely leaked anywhere else unless it was a bad installation (bunching in the seal) or there was an issue with the windshield frame.
Old 01-01-2018, 02:55 PM   #7
Rufas
Rufas's Avatar
Is that between the glass and the rubber seal or the rubber and the body channel?
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 01-01-2018, 03:03 PM   #8
truckster
truckster's Avatar
Between the rubber and the body.
Old 02-08-2018, 10:48 AM   #9
crabman
crabman's Avatar
Has anyone had the glass and rubber seal leak? I'm asking because that's what it looks like in my 69 C10. When it rains I see water come up from the rubber seal and drip down on the dash, drips on both lower corners. It is a new seal and glass installed by the previous owner.
1969 CST/10 396
crabman is offline   Reply With Quote
Old 02-08-2018, 11:11 AM   #10
LockDoc
The Older Generation
LockDoc's Avatar
Try using some sealant 6 inches over and 3 inches down from the top corners, between the rubber and the cab and see what that does. Also be sure and check the drip rail for any bad spots in the sealant there.
LockDoc
Leon
Old 02-08-2018, 11:50 AM   #11
crabman
crabman's Avatar
Thanks Doc, I wasn't sure if the sealant between the rubber and body would fix what I am seeing. I will try what you suggest and se where that gets me.
1969 CST/10 396
Old 02-08-2018, 12:05 PM   #12
LockDoc
LockDoc's Avatar
If you see any rain before too long report back and let us know either way.
Thanks,
LockDoc
Leon
Old 02-08-2018, 12:17 PM   #13
demian5
demian5's Avatar
I had to use windshield sealant in the upper corners of mine only, but that was after a dry installation.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 02-08-2018, 08:01 PM   #14
crabman
crabman's Avatar
I applied some windshield sealant this afternoon so when I get some rain I’ll see if it worked
Old 02-16-2018, 09:53 PM   #15
crabman
crabman's Avatar
Unfortunately my windshield still leaks. The dripping on the floor is less but the water coming in around the seal and glass at the bottom is still happening. I'm not sure what the next move is, I don't want to remove the glass and seal since they are new.
1969 CST/10 396
