Old 02-10-2018, 02:06 PM   #1
heritagewraith
'67 292CID 6 cylinder
Good morning all; I tried started my P-30 Stepvan this morning. It seems as though it was flooded. It finally started with a real rough idle, dying without foot on pedal. I looked down and noticed oil and gas coming between head and block. I have general knowledge. I just want to narrow down items when going to the parts house...Blown head gasket??? Simple fix???
heritagewraith is offline   Reply With Quote
Old 02-10-2018, 02:23 PM   #2
harpo231
harpo231's Avatar
Re: '67 292CID 6 cylinder
Sounds like it,,, check oil and coolant , see what they look like ...
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 02-10-2018, 02:29 PM   #3
heritagewraith
oil is black. coolant is green. I suspected a loss of compression. I originally thought I simply had a lot of water in gas tank. I wants to start, getting fuel scenario. Then, almost as soon as it started, I looked down saw the oil coming out between head and block. No idle when foot off of pedal.
Old 02-10-2018, 02:40 PM   #4
harpo231
harpo231's Avatar
Cam seals or valve covers ?
Stan
67 swb BLU MULE
Old 02-10-2018, 02:45 PM   #5
heritagewraith
Valve cover.
Old 02-10-2018, 05:48 PM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
Try a compression check.
'68OrangeSunshine is online now   Reply With Quote
Old 02-10-2018, 06:43 PM   #7
heritagewraith
Yes, that sounds like something I might be doing...In the very new future.
Old 02-10-2018, 07:20 PM   #8
Grumpy old man
Grumpy old man's Avatar
Show a picture of your engine and where you think the oil is coming from , Is it a slow leak or shooting out ? Never seen oil leaking out from a blown head gasket . Pull the plugs and see what your working with .
Old 02-10-2018, 09:19 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
Oil feeds through the push rods to the top end, so you should not be seeing oil coming out between the block and head. Well, if something catastrophic happened, you could. Pics, as requested previously, will help.
~Steven
Simi Valley, CA
Old 02-11-2018, 04:04 PM   #10
heritagewraith
Good morning all;
I went out there this morning to look at it. It is gasoline that is coming out. Just a black residue, making it look like oil. I am going to post pictures, in a few.
Old 02-11-2018, 11:39 PM   #11
'68OrangeSunshine
Originally Posted by heritagewraith View Post
Good morning all;
Check your carb connections and mounting studs. Is this the Rochester MonoJet?
