02-12-2018, 08:36 PM | #26 |
Re: Project High School Reunion
Got the new dash cluster and glove box cut out today
02-12-2018, 09:43 PM | #27 |
Here is the back side of the glove box, I put a spot for the SPID and the drink circles
02-13-2018, 01:16 PM | #28 |
Here is a shot with the gauges in
04-11-2018, 06:36 PM | #29 |
Got most of the interior out and got all the guts out of the doors.
04-22-2018, 06:24 PM | #30 |
With the nice weather, I got the inner fenders and core support painted.
Also fully stripped the cab, no rust and will be all original gm metal. Even the window channels don’t even have a start if rust. |
08-15-2018, 07:37 PM | #31 |
Been really busy with work. Got the cab all ready for media blasting. There were holes from a cb, aftermarket gauges, switches, dual fuel tank switch, old floor shifter hole from my youth, and several firewall holes from an aftermarket a/c.
Got the cab off, started tearing the front end off |
08-31-2018, 06:32 PM | #32 |
Got the frame sandblasted and primed, about a dozen more parts, and I can start re assembly 🎉
09-06-2018, 07:13 PM | #33 |
Got the cab back from the media blaster, got it blasted inside and out and epoxy primer.
All gm metal, now the hard work begins Ed |
10-26-2018, 02:57 PM | #34 |
Finally had time and decent weather to paint the frame, I can start reassembly soon!
10-26-2018, 04:10 PM | #35 |
landarts
Very nice job on the truck! I really like your color choice, sort like the original Copper Poly but much darker. Is that your CNC machine in the picture, if so what type?
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
10-26-2018, 05:12 PM | #36 |
Ez-router
It’s amazing what you can do with them Thank you Ed |
10-28-2018, 06:51 AM | #37 |
Nice progress- you’re doing it right
01-19-2019, 05:31 PM | #38 |
Thanks tigger,
I have been swamped with work and haven’t been on here or the truck. Finally spent a few days on her and I am back on 4 wheels! I put cpp dropped spindles and drop rear springs. Now I need to get the engine tranny and brake lines in.
http://67-72chevytrucks.com/vboard/s...d.php?t=704228 http://67-72chevytrucks.com/vboard/s...d.php?t=732764 Last edited by Nh4clo4; 01-19-2019 at 05:40 PM. Reason: Misspelling |
11-29-2020, 12:00 PM | #39 |
Well after a long hiatus due to a heart attack last year, finally have time to to get back on it, got the engine, trans, and drive shaft installed.
11-30-2020, 01:37 AM | #40 |
Good work! Glad to hear you made it through that ordeal alright. One of my best friends had a double bypass last year, and feels so much better now that his pipes have been cleaned out his blood flow is so much better. I hope you can say what he says, "I feel like a new man"... I'll be watching for more updates!
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
11-30-2020, 08:40 PM | #41 |
Thank you for the support, it made me realize I better finish this before my family needs to deal with it!
12-05-2020, 07:15 PM | #42 |
Got all the engine accessories on, minus carb and distributor.
Pulled it outside a rinsed the dust off. Now I can cover it and get the cab ready to put on |
12-05-2020, 08:31 PM | #43 |
Looking good !!!! Keep the pictures coming & the progress going forward & keep on truckin'.
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15. Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e, |
12-05-2020, 08:41 PM | #44 |
Thanks, I had a hiatus for health, and am feeling really good and getting more enthusiastic on it
02-09-2021, 08:23 PM | #45 |
Cab is getting close for paint and install in the frame,
Inside and top is block sanded and ready for paint. Made a cart to get it off the ground so I can get the bottom half block sanded and then paint! |
02-10-2021, 12:07 PM | #46 |
Almost Satisfied
Getting paint on the cab and it back on the frame is such a big motivator. Glad you are still working on it.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
02-10-2021, 01:32 PM | #47 |
Yep, gotta finish it this year. It is so close, all the body panels are in primer, so once the cab is done it should go faster, there is a lot of real estate on the cab to prep.
Thank you for the support |
02-27-2021, 07:30 PM | #48 |
After several weeks of sanding, finally got the cab painted and ready to put it back in place
Posted via Mobile Device |
02-27-2021, 07:30 PM | #49 |
Mr. Cheyenne
I recognize that color - fabulous!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
02-27-2021, 07:50 PM | #50 |
Looks great!
71 C10 72 K20 72 K10 Super Kirk |
