02-13-2018, 11:11 PM | #126 |
Re: Brother's keeper - '58 Stepside build
I took a break from sanding and got some more done on the interior. Before reinstalling the newly modified brake pedal I finished installing the sound deadening on the cab floor and pieced together some 40oz jute carpet padding for the cab floor and toe board.
02-24-2018, 12:57 AM | #127 |
Waiting for paint to dry, I whipped up an aluminum mounting bracket for the tach. I think it looks much better than the stamped tin bracket that came with the gauge cup...
02-24-2018, 09:22 AM | #128 |
Nice....
03-09-2018, 02:06 PM | #129 |
The custom tach I ordered from Speedhut showed up while we were on vacation so I got it wired up and installed. I need to find some small diameter loom before I can connect the wires.
Just before leaving I mocked up the stereo system and installed the antenna behind the seat. Reception is very good and the sound quality is better than expected. |
03-09-2018, 02:27 PM | #130 |
Wiring done, The green colored cover for the column and tach wiring will get painted gloss white to match the column.
03-09-2018, 07:09 PM | #131 |
Nice
03-09-2018, 09:04 PM | #132 |
Awesome work!
03-13-2018, 11:41 PM | #133 |
After sorting out the turn indicator wiring, the instrument cluster is in and functioning properly.
03-14-2018, 01:10 PM | #134 |
Looks REALLY good!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
03-14-2018, 01:54 PM | #135 |
I love those green line gauges!! I used to have them in my '55 Belair!
Take Care Troy |
03-14-2018, 02:29 PM | #136 |
Looks really nice Mark, that two-tone dash came out just perfect and the gauges are totally fitting to it all.
My Build: 57 Chevy Pro-Street |
03-16-2018, 12:04 AM | #137 |
Doing the carpet now so I can have binding sewn on the edges. I was going to try to do it in one piece but now I'm leaning towards cutting a U shaped relief for the hump and make a second piece to cover the hump, slightly overlapping along the edge. There should be enough carpet left over to make some floor mats too.
03-16-2018, 08:15 AM | #138 |
That's going to look real nice
03-16-2018, 09:04 AM | #139 |
Looking good...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
03-17-2018, 05:53 PM | #140 |
Fed Ex called to set up a delivery for the bed sides I ordered from Mar-K. Since the terminal is only 15 minutes away, I picked them up this morning. Nice quality and very well packaged for shipping.
Anyway, my youngest was home so she helped me get the sides in place and held them until I could get a few bolts in. I installed the tail gate and got everything squared up, it went pretty easy. The rear sill didn't have holes for the license plat bracket so I got that done, the tail lights were installed to make sure all of the holes line up. |
03-17-2018, 06:06 PM | #141 |
Nice... you decided not to go with your originals?.. I remember on the other forum when you radiused the ends...
03-17-2018, 06:16 PM | #142 |
I know, all that work and I'm not going to use them. There was a lot of hidden issues discovered after I stripped the old paint and filler.
03-24-2018, 01:30 PM | #143 |
Got the fuel tank vent done and finished fitting the carpeting. I even had enough left over to make a one piece front floor mat.
03-24-2018, 06:30 PM | #144 |
Mocking up the steps and doing a little bodywork...
03-24-2018, 06:56 PM | #145 |
Man, that Carpet Looks Nice! It sure is goin to be a eye catcher when your Done
03-24-2018, 07:24 PM | #146 |
Great work.....
03-25-2018, 11:54 PM | #147 |
Last fender, SEM guide coat followed by block sanding revealed some low spots. Brand new rear fenders were far from perfect...
03-31-2018, 03:02 PM | #148 |
After body working the rear fenders, I got them on for final mock up...
03-31-2018, 05:48 PM | #149 |
Looking good.....
04-02-2018, 10:39 PM | #150 |
The last big hurdle is the doors. They are in great shape and won’t need much bodywork. I spent the evening removing an excessive amount of 3M yellow weatherstrip adhesive, finding and opening up drain holes and cleaning out a ridiculous amount of nuts, bolts, washers and general debris that was inside the doors...
