02-18-2018, 03:53 AM | #1 |
Gas Pedal Options
I have given up trying to find a 71 - 72 C10 gas pedal for my 64. They just are not out there.
What have other folks used instead? Lokar perhaps? Some other brand? I have a Lokar cable but have not installed yet. Thanks for the help. |
02-18-2018, 06:52 AM | #2 |
Moderator
Re: Gas Pedal Options
I have a 72 I am going to use.
But I can see why either of these couldnt be used: https://www.ebay.com/itm/1972-82-cor...daci5F&vxp=mtr https://www.ebay.com/itm/1972-73-74-...5ZUHLO&vxp=mtr
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 02-18-2018 at 07:23 AM. |
02-18-2018, 08:54 AM | #3 |
73-87 should be same pedal/linkage setup as the 71-72. That may give you some more options.
02-18-2018, 02:04 PM | #4 |
I think the Corvette gas pedal assy Rocknrod posted would be your best bet. I ended up using a pedal assy from a 75 Pontiac but had to heat & bend it to make it fit properly then used the plastic pedal from a 73 or so Nova.
Here's what I started with a brake pedal from a 73 C-10 and a gas pedal assy from a 75? Pontac. Here's what I ended up with after I heated & bent the Pontiac gas pedal & added the Nova gas pedal. You can see my heat & bend areas on the gas pedal if you look closely. Next up is the stainless pedal trim used on GM cars from around 69 to 74. After that I'm getting rid of the E brake pull handle assy and adding a floor E brake assy from a 72 Caddy. Last edited by 64shortbox; 02-18-2018 at 09:42 PM. Reason: Add Pictures |
02-18-2018, 10:26 PM | #5 |
Thanks Rocknrod! I'll go with the 72 Corvette pedal assembly. I think I can make that work.
02-19-2018, 02:22 AM | #6 |
I went with a Lokar pedal assy. for a 67-70 C10.
02-19-2018, 11:01 AM | #7 |
On my 1966 GMC 2500 2wd I used a 73-87 assembly to replace the floor mounted pedal with rod linkage.
The 73-87 pedal is attached to a larger bracket assembly. I trimmed off everything but the pedal mount.
1966 GMC 1 Ton 305 V6 SM420 4 speed - retired Fire Dept Support Truck from Little Falls, NJ My GMC Photos |
02-19-2018, 11:10 AM | #8 |
DLW that pedal assy looks good
that's exactly what I am looking for thanks Michael
1962 chevy short and wide 2015 z71 1967 SS Chevelle |
02-19-2018, 12:32 PM | #9 |
02-20-2018, 12:14 AM | #10 |
I used one from a '95 C-1500. I had to bent the arm where the cable attaches a little, and i welded a small segment of tubing onto the pedal end to form a curved shoe that the stock floor mounted pedal could ride on without binding. It's worked pretty well for over a year now.
02-20-2018, 01:20 AM | #11 |
I just bought a 98-2003 s10/blazer gas pedal off ebay for 15 bucks. Haven't mounted it yet but from just holding it up to the firewall in my 65' it looks to me like it will fit like it was made for the truck. I will post some pics this week when i get it finished up
02-20-2018, 08:11 AM | #12 |
I used an S10 from the junk yard.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-09-2018, 12:43 AM | #13 |
olds intrigue
