Old 02-20-2018, 05:11 PM   #1
6768chevylover
6768chevylover's Avatar
15x12 wheels?
I'm curious to see if anyone is running 15x12 with 33" tires with a 2.5-3" lift?
6768chevylover is offline   Reply With Quote
Old 02-23-2018, 05:35 AM   #2
Green Monster
Green Monster's Avatar
Re: 15x12 wheels?
I'm not running 15" x 12" wheels but instead running 15" x 10" wheels with a 3" lift. The tires are 33 x 12.50. Hopefully the pictures give you an idea of how this lift looks with a slightly more narrow wheel.
Green Monster is offline   Reply With Quote
Old 02-23-2018, 09:05 AM   #3
68panelman
68panelman's Avatar
Re: 15x12 wheels?
Do you have any rubbing?
I have 15x10's I plan on mounting some day. 4" front, 3" rears, currently running 35's and rallies, but want to drop down to 33's, (3:08 rears). Your Blazer is one of my favorite ones out there, set up perfectly
68panelman is offline   Reply With Quote
Old 02-23-2018, 01:11 PM   #4
6768chevylover
Re: 15x12 wheels?
I agree with you on that one. It blows mine away and I get a lot of compliments on mine. I'd like to see it in person one day.Your about a couple of hrs away from me(Green Monster). Thanks for the reply, it helps out. You don't happen to know the back spacing on your wheels?
Old 02-23-2018, 02:30 PM   #5
Green Monster
Re: 15x12 wheels?
Thank you for the compliments.
I've attached a few more pictures to give you an idea of how the stance is set up. The front tires stick out beyond the fenders so I personally like wouldn't run anything wider than 10 inch wheels and 12.50 tires. The rear tires sit flush to fenders though.
I've never had any rubbing with the tire wheel combo I'm running. I drive on the streets only so I don't know if it would rub if the suspension moved more with some off road action.
It's been a while since I bought the wheels but I'll see if I can find the backspacing info.
Old 02-23-2018, 10:50 PM   #6
simicrintz
Re: 15x12 wheels?
Another vote here for a great looking rig!
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
Old 02-25-2018, 08:17 PM   #7
Mike C
Mike C's Avatar
Re: 15x12 wheels?
A 12" rim is too wide for a 12.5" wide tire. 10 is as far as I would go but 9 is probably better (easily done if you go to 17" rims).
I have 9.75 wide 16.50 rims on my Jimmy with 35 12.5 16.50 BFG AT's. They fit great. They replaced a set of 35 12.5 15 BFG MT's on 15x10 Centerlines which was fine as well.
I used to have a set of Bart's 15x12 wheels with 35 14.5 GroundHawgs on them and the 12" rim worked for that width tire, but it was STUPID heavy and wide. I wouldn't even think about 12" wide rims.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-26-2018, 01:01 AM   #8
Green Monster
Re: 15x12 wheels?
The backspacing, according to my measurement, is 3 5/8".
Old 02-26-2018, 04:33 AM   #9
Killer Bee
Killer Bee's Avatar
Re: 15x12 wheels?
if you can find the specs for the tires you're looking at, should list suggested rim width range..
and remember section width given in the tire size is not actual width, actual tread width will be narrower..
and rim widths will be close to tread width down to as much as 1-2" narrower depending on sidewall design..
check the specs on these for reference;
ALL-TERRAIN T/A KO2 - SIZE: LT33X12.5R15
these are 33x12.55r15 Thornbirds on 8.5" Western Hurricanes, and Interco recommends 10"
Thornbird
these are 9.00x16 Super Lugs on late model 6.5" takeoffs.. spec calls out 10.4 wide at 36" tall on 6.5" rim..
SUPER TRAXION, SUPERLUG TUBELESS
good luck!
Old 03-06-2018, 02:23 AM   #10
Green Monster
Re: 15x12 wheels?
Here's a picture of a Blazer Chalet that I stumbled across with 12" wide wheels. Great looking truck and the 12s look great on this setup but I wouldn't go beyond 10" wide wheels without the chalet.
