Old 02-21-2018, 12:18 AM   #101
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Re: Anyone running CB's in their truck these days?
So I’m dying to ask what kind of antenna THAT thing needs? Got a pic? I’ll show my ham stupidity here, but i didn’t even know there even was such a thing as a mobile ham. That’s cool.
IMHO the best route is a "screwdriver" antenna.
It is a tunable antenna that uses contacts on a motor driven coil to change the impedance of the antenna.
With that setup you can hit stations that are as far away from the west coast as Japan, Hawaii, Russia, it will really get out!
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 02-21-2018, 12:46 PM   #102
70cst
70cst's Avatar
Originally Posted by bbrriiaann1973 View Post
Ok good for you
Its time to simmer down ... wrong attitudes are a no no.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 02-21-2018, 02:14 PM   #103
jocko
jocko's Avatar
Excellent info, thanks very much Mr. B.
Old 02-21-2018, 05:33 PM   #104
bbrriiaann1973
So you think I am the only one that needs to simmer down?
Brian Ritter
bbrriiaann1973 is offline   Reply With Quote
Old 02-21-2018, 05:53 PM   #105
slomotion
Old Duffer
slomotion's Avatar
And here I am, late to the party again!
I did some serious soul-searching before I drilled the holes for the mount, but figured worse-case scenario I may have to repair them at some time, or, just leave the radio there. Not the end of the world either way. Ran the antenna wire back to the headache board, installed a bracket there for the whip. Only downside was I had to run a ground wire back to the cab just to insure a good ground.
In the first photo the white speckles on the headliner are reflections from the radio knobs. In the last image the antenna has been removed (quarter-twist) so it didn't get bent up going in the garage.
'68 Short C20 Flatbed Dually
w/ 292 4bbl, Langdon cast headers,
and WC T5 trans.
'81 G10 Shorty Van
"Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers
"Under promise, then over achieve."
slomotion is offline   Reply With Quote
Old 02-21-2018, 11:03 PM   #106
70cst
70cst's Avatar
In my comments Yes!
Old 02-21-2018, 11:04 PM   #107
70cst
70cst's Avatar
Very nice
Old 02-21-2018, 11:32 PM   #108
Rods
Rods's Avatar
Slomotion I think I know the answer but will ask anyway. Why did you mount the cb were you did ? I’m thinking because of the shifter and it (CB) being in the way ?
Im building the same truck as yours and have looked at pictures and have studied your truck to get ideas for mine. Very nice by the way.
Rods is offline   Reply With Quote
Old 02-22-2018, 07:46 AM   #109
slomotion
Old Duffer
slomotion's Avatar
Thank you 70cst!
Thank you Rods!
You're right, under the instrument panel was not very convenient, and the mic cord and shift lever would have been wrestling each other all the time . A couple of other considerations were the radio speaker is on the bottom of the transmitter so I didn't need an external speaker this way and I didn't want it on the dash because it was too visible from outside. I guess another reason was habit. I drove commercially for a lot of years and just got used to the radio being overhead and easily visible to me.
and WC T5 trans.
'81 G10 Shorty Van
Old 02-22-2018, 10:46 AM   #110
Noah96
Any recommendations on a decent antenna for a 40 channel radio shack cb. Going on a 1969 GMC C2500.
Noah96 is offline   Reply With Quote
Old 02-22-2018, 11:32 AM   #111
MrBeast
high-Tech Red Neck
MrBeast's Avatar
I have always loved the Firestix 2's, tune em up with an SWR meter in an open field, and you will get out well with them.
Old 02-22-2018, 11:38 AM   #112
Ironhorse
Ironhorse's Avatar
Noah, I used a pair of twin "Hustlers" when I was doing the CB bit. Got out well with them. Not sure if still have them in the garage or not. Could look and see if still have them. Think they were 40'' long if I remember. Ran them with a splitter for the two antennas.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 02-22-2018, 01:57 PM   #113
jocko
jocko's Avatar
I like the dual antenna look on the mirrors like semis had, but always though that you needed to be as wide as “semi truck” distance mounting separation for them to actually be more advantageous than a single antenna(??)
Old 02-22-2018, 11:21 PM   #114
MrBeast
high-Tech Red Neck
MrBeast's Avatar
if you have the west coast style mirrors you can mount them where the mirror ties into the main mount tree, that will work just fine, will be about the same width as on a semi.
Old 02-22-2018, 11:27 PM   #115
70cst
70cst's Avatar
Agreed!
I will be mounting Twin Antenna ...
Old 02-22-2018, 11:31 PM   #116
70cst
70cst's Avatar
Twin "Hustlers" can still be purchased...
Old 02-22-2018, 11:43 PM   #117
jocko
jocko's Avatar
Solid copy Good Buddy! Ha. Ok. It’s been awhile.. thanks Mr. B.
Old 02-22-2018, 11:44 PM   #118
MrBeast
high-Tech Red Neck
MrBeast's Avatar
I am playing around with an idea for hiding the screwdriver element inside of the bed and using a long whip like on the Fall Guy truck.
Old 02-23-2018, 12:03 AM   #119
'68OrangeSunshine
'68OrangeSunshine's Avatar
Mr Beast, I seem to recall a device [black box] that was cut-in to the coax of one side of a twin mirror mount -- which by tuning a variable capacitor -- could sweep the focus of the bi-polar pattern into a directional array. The nominal radiation of ''rabbit ears'' was a figure eight, but changing the signal could make it cardioid, and also onmidirectional.
For on-highway use, the fore-and-aft signal of the bidirectional set up is probably best, but a variable sweep function is interesting.
Is there more to it than just a variable capacitor? I remember proprietary black box devices being available, some decades ago.
Old 02-23-2018, 12:16 AM   #120
MrBeast
high-Tech Red Neck
MrBeast's Avatar
I am sure you are right about that, although I have not ever seen one.
On my sailboat I have an Isolated backstay with a tuner on it that really works well, I have talked to Japan and Alabama with it from Puget Sound.
Old 02-23-2018, 08:07 PM   #121
70cst
70cst's Avatar
Any others have a CB in their Truck?
Old 02-23-2018, 08:40 PM   #122
jeffahart
jeffahart's Avatar
I always liked a whip. I've tried to find the military style 'S' clips to hold an antenna whip down. You would clip upper clip in the bush so if antenna gets caught on a branch it pulls off and breaks away. In city(MOUT) you clip under so antenna cannot accidentally come loose and catch a power line. I always thought that was clever. You would get a serious reprimand in the bush with using an under clip(Potential to break the whip) or over clip mount on highway(potential for catching a power line). If you broke a whip in the bush you had some splainning to do!! Always looked for a civilian equivalent but never found one. Here's a pic below.
I stayed clear of this thread because I knew it would make me want a vintage CB, yet here I am... I want!
j
White K20
jeffahart is offline   Reply With Quote
Old 02-23-2018, 08:44 PM   #123
70cst
70cst's Avatar
Originally Posted by jeffahart View Post
I always liked a whip. I've tried to find the military style 'S' clips to hold an antenna whip down. You would clip upper clip in the bush so if antenna gets caught on a branch it pulls off and breaks away. In city(MOUT) you clip under so antenna cannot accidentally come loose and catch a power line. I always thought that was clever. You would get a serious reprimand in the bush with using an under clip(Potential to break the whip) or under mount on highway(potential for catching a power line). If you broke a whip in the bush you had some splainning to do!! Always looked for a civilian equivalent but never found one. Here's a pic below.
Attachment 1756009
j
23 Channel CB's which are period correct for our trucks .. are cheap to purchase unless you go after the high end radios ...
Old 02-23-2018, 09:01 PM   #124
jeffahart
jeffahart's Avatar
Hey thanks! Are you talking something like this(link below) what do you think of this radio?
https://www.cobra.com/products/professional/29-ltd
j
White K20
Old 02-23-2018, 09:25 PM   #125
70cst
70cst's Avatar
j
If you want a period correct CB for our trucks ... it needs to be 23 channel. It was about 74-75 is when the FCC opened up the radios to 40 channels. You can pick up a very nice radio for about $40. Cobra, Uniden, Midland, Radio Shack (Realistic), Tram, Johnson, Royce, Browning... the list goes on.
