Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-20-2018, 05:02 AM   #1
a Good Man
a Good Man's Avatar
Radio AM- FM 69-72
Hi all
I'm seriously considering buying this radio in the next few days but I do not know what the right speakers are for this type. The original speaker does not work. What advice to clear voice without problems ?
https://www.ebay.com/itm/1967-1969-C...53.m1438.l2649
MY Facebook
( saad_alhajri ) on Instagram
a Good Man is offline   Reply With Quote
Old 02-20-2018, 09:27 AM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Radio AM- FM 69-72
That's an aftermarket radio. It is a stereo radio which needs more modern speakers. The factory am/fm radio was a mono speaker.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-21-2018, 01:31 AM   #3
a Good Man
a Good Man's Avatar
What are the appropriate speaker ?
MY Facebook
Old 02-21-2018, 05:17 AM   #4
ericfallon
Assuming you are only going to use the center dash location for speakers,
then something like this
http://www.classicpartsusa.com/produ...8aAlAmEALw_wcB
They make kick panels that hold speakers for these trucks if you want more sound that 2 small 3.5" speakers in the center dash.
ericfallon is offline   Reply With Quote
Old 02-21-2018, 06:33 AM   #5
Killer Bee
Killer Bee's Avatar
from the ebay ad description;
  • Maximum power = 180 watts RMS (45 watts x 4 speakers 4Ω, 14.4V, 1kHz)
  • Do not use original speakers
  • Additional line outs and output options: 3 RCA jacks for left channel, right channel, and sub-woofer
  • 3.5 mm phone jack for input from iPod, satellite radio or MP3 player
  • Switch selectable for 1,2,3 or 4 speakers
speaker ratings listed as well as line level outputs for an external amp if that's your goal..
also selectable for 1,2,3, or 4 speakers so you could run a single modern speaker in stock location..
you mention clear voice as your objective so you could buy an actual analog factory stock am/fm with stock replacement speaker for those results..
depends on how 'original' you're trying to achieve..
as for the modern speakers that will sound decent for music and voice, sky's the limit depending where you're planning to install them..
this might be a good place for you to start to see what sizes are available withing the output specs of the head unit you're looking at..
https://www.crutchfield.com/S-lRuQ8k...kers-Subs.html
good luck!
Old 02-22-2018, 08:06 AM   #6
a Good Man
a Good Man's Avatar
I have purchased all the necessary thank you all.
MY Facebook
