Old 02-22-2018, 08:15 PM   #1
Thundarr
Thundarr's Avatar
Planning Ahead - Engine Swap
My 71 Sierra Grande has a late 80's GM Goodwrench 350 SBC with 3 speed auto. I have no idea what the actual miles are on the drivetrain. It runs well as I have updated everything short of an actual rebuild but lacks any real cajones.
If and when this motor or tranny dies, I want to be ready with it's more reliable and powerful replacement. That could be tomorrow, but I think I have some time. Can you offer up some experienced suggestions on what I should start to assemble.
I'd like to have somewhere in the upper 300 range horsepower and torque. I don't need to melt any tires, but i'd like some power when I need to haul or pass someone in traffic.
LS conversion or something more easily swapped with the parts I've already upgraded?
Which transmission?
1971 GMC C15 Sierra Grande SWB
1972 Chevy C10 Custom Deluxe LWB
2018 GMC Yukon Denali
Thundarr is offline   Reply With Quote
Old 02-22-2018, 09:57 PM   #2
garyd1961
Re: Planning Ahead - Engine Swap
GM L31-R crate motor with a TCI Street fighter th350 trans is what I'm running. The only problem I had was the pan gasket on the trans leaking which seems to be a common thing. I got it fixed with a new gasket but if it ever leaks again I think I will install a better oil pan.
garyd1961 is offline   Reply With Quote
Old 02-22-2018, 10:09 PM   #3
HO455
HO455's Avatar
What kind of budget are you living with? What updates have you done to your current engine? Have you done a compression test on the current engine?
Just like real estate people have a saying so do we " Pictures pictures pictures "
RIP Bob Parks.
Old 02-22-2018, 11:32 PM   #4
truckster
truckster's Avatar
Another vote for the L31 Vortec. It's a great, reliable motor. Put in an HT 383 cam and you'll be running around 330 HP and close to 400 ft/lb torque with rams horns manifolds and a Quadrajet.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 02-23-2018, 12:31 AM   #5
Thundarr
Thundarr's Avatar
I'll get some pictures tomorrow. It's definitely no dog, but it drives like a 70-80s SBC. Here is the low down.
I've owned it for 5 years. Valve clearance and cylinder compression was checked when I purchased and everything was good there.
This is what I've done to the drivetrain:
Exhaust Headers, Carb clean out, Corrected timing, Replaced intake gasket, New plugs/wires, New Alternator, Electric Fans, Replaced all vacuum lines, All New fuel lines with under bed tank relocate, New fuel pump, Transmission rebuilt, Rearend rebuilt. Probably more, but I think I've run out of tricks to squeeze more out of it.
I love this truck and will keep it forever, God willing, so the budget limit is fluid as I assemble the upgrade. But at the same time, I want to be rational with it. I'm thinking 5-7k.
Old 02-23-2018, 12:42 AM   #6
Thundarr
Thundarr's Avatar
Nice to see two of the same.
Can I use the same headers and what about the vacuum operated ac/heater valves and brake booster?
What transmission do you have? I'm sure that getting rid of the 3 speed will help alot.
Old 02-24-2018, 05:04 PM   #7
Thundarr
Thundarr's Avatar
Engine Bay
Old 02-24-2018, 05:15 PM   #8
mikecaddy500
mikecaddy500's Avatar
Smile Re: Planning Ahead - Engine Swap
Add a bigger cam and a pair of vortec heads and intake
mikecaddy500 is offline   Reply With Quote
Old 02-24-2018, 07:56 PM   #9
truckster
truckster's Avatar
You can use the same headers and you'll have plenty of vacuum. I'm running a TH350 and NP205 transfer case.
You will need a different intake manifold, as the bolt pattern is different. You'll probably need an electric fuel pump too. Most of the Vortec blocks aren't drilled for a mechanical pump.
Old 02-24-2018, 10:51 PM   #10
Brofle1402
Buy a set of good heads AFR or Trick Flow, 480 to 490 lift cam and a injection unit
Brofle1402 is offline   Reply With Quote
Old 02-24-2018, 11:03 PM   #11
1972RedNeck
1972RedNeck's Avatar
Big block will get you there...
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
