04-29-2004, 05:06 AM | #1 |
What I drive
700r4 to th-350?
I think I am going to swap the broken 700r4 for a th-350 and need to know what is needed and what needs to be done? I know I will need a th-350 with the 9inch tail shaft. Will the xmember work? Will the flywheel work? Will the driveshaft work? Thanks
1986 Chevy Crew Cab Dually(Choo-Choo Conversion) 2006 Chevy Equinox |
04-29-2004, 09:39 AM | #2 |
The Flex plate I am pretty sure will work. I think the crossmember will work fine but you may need to drill new holes i nthe frame. The main body of a TH350 is about 1.5 inches shorter I think.
You also need the TH350 Carb bracket for the Down shift cable. I think the 700 is spaced different. Tag the intake port behind the carb for the Modulator. Shifter should work but you will not use 1st. OD will be 3rd.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
