Old 02-26-2018, 11:20 AM   #1
bootman49
HO52 rear gear
Where can I find photos of 3 different gear cariers , open, locker, limited slip, for visual I.D. of each HO52/HO72?
bootman49 is offline   Reply With Quote
Old 02-26-2018, 01:16 PM   #2
Bigdav160
Bigdav160's Avatar
Re: HO52 rear gear
I don't they were ever offered with 3 series gears.
Sorry totally mis-read your question. I think there's a good thread on the HO52, right right here with some pics.
From the outside the differential cases look very similar. Everything is hidden inside.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-26-2018, 02:40 PM   #3
bootman49
Re: HO52 rear gear
Thank you big dave, gonna take a while to go thru that one. I am searching for a 410 gear to swap out 5:14 / HO72. I would like to know what to look for to ID limited slip or open. Photos will help and that thread has some.
Old 02-26-2018, 09:20 PM   #4
Mike C
Mike C's Avatar
Re: HO52 rear gear
There are only (2) differential options. The Maximum Traction "Detroit" Locker and the open. They fit inside the carrier so externally they look the same.
I'm pretty sure you can use 14 bolt internals if you swap to 30 spline axles. Check out the HO52/72 thread on Pirate4x4.com
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-26-2018, 11:37 PM   #5
bootman49
Re: HO52 rear gear
Mike, thanks but looking to just pop one in. I have a 1-ton 3800 series.
