03-01-2018, 01:15 AM | #1 |
Brake drum problems
I swear, one of these days I will start a build thread.
So here is my problem, I have an 85 2wd C10 with rear drums. I got new rims and took off my old ones to paint the drums and front calipers. I took the drums off, hit um with a wire brush, a few coats of paint (only on the outside ... in case someone felt the urge to ask) and slid them back on. Shoes had plenty left on them so, no need to change. Then I put my wheels back on and fired her up to spin the truck around in the garage and the back lock up when I hit the brake pedal. I can drive up and down the driveway fine with no apparent drag but, when I touch the pedal, BOTH rears lock up. When I let off the brake pedal, they release fine. Pedal has good pressure just like before I started. Even when I roll forward a little bit in Drive and tap the brake, they lock but as soon as I let off the pedal, they release and the truck continues forward. I dont get it... brakes were perfectly fine before I started and I didn't change anything in the rear. Any ideas?
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 Last edited by 808_67C10; 03-01-2018 at 01:33 AM. |
03-01-2018, 08:12 AM | #2 |
Re: Brake drum problems
Some possibilities: overspray paint lightly coated either/and insides of drum and shoes. Other contamination did same. You swapped the left and right drums and the drum wear groves and such now no longer match the shoes.
03-01-2018, 11:05 AM | #3 |
I was very careful not to get paint inside the drums... but, I will pull them apart and check... a lil over spray may be a possibility. Didn't really look inside after I sprayed them. I did one side at a time so, no possibility of a swap.
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
03-01-2018, 11:38 AM | #4 |
some times my old 1ton will get rear grabby the first few hits when there is a huge moisture level swing from lots of rain or snow . does it more when i dont drive it every day .
good blast up the road and feather them in burns the moisture out .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
03-01-2018, 12:04 PM | #5 | |
I am going to pull it apart tonight to see more.
03-01-2018, 01:41 PM | #6 |
The pads ride on little bumps in the backing plates, and their 'tightness' is controlled by the adjuster.
Most likely what happened is the drums are a little sloppy on the center hub and when you installed them they shifted. Pull the wheels and put the drums on with 2 lugs finger tignt and spin them. If there is a tight spot turn it to that point, then pull the lugs off and install the wheel. The drums should recenter and be better. Alternatively put on the wheel just finger tight, so the drum can still move, then spin it around slowly until the tight spot is lessened. Then tighten the wheels. If that doesn't fix it you'll have to go back in. First, note which way the adjuster star wheel needs to move to allow the shoes to move closer together at the boot. Lift the adjuster tab off the star wheel and back the star wheel off 3-4 teeth. Second, look at the bumps the shoes ride on and see if they are flat, if not, a light filing is in order. They tend to get a notch worn in them and the shoes can grab ther. The service manual cauls for a tiny dab of grease, I usually use just enough to leave a film so the bumps don't rust.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
03-01-2018, 02:29 PM | #7 | |
03-02-2018, 11:09 AM | #8 |
Pulled the wheels, tried to reseat the shoes, cycled the e brake a few times, even tried to swap the drums to see if it was a warped or cracked drum. Also, I took some 220 grit to the shoes and drum to make sure there wasnt any overspray causing the problem.
When I spin the rear I can feel it grabbing in one spot on the drivers side. I tried to tighten the star adjuster to bring the shoes together and was able to get it so the wheels spun freely, then set it down and drove in reverse and forward... the problem is still there. Its only really bad when I go forward, they dont lock when I am backing up and hit the brakes. No grooves on the 6 pads that the shoes ride on either. This is driving me crazy. Should I yank it all apart and replace the shoes n brake hardware? I hate just replacing things till I find the problem...
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 Last edited by 808_67C10; 03-02-2018 at 12:23 PM. |
03-02-2018, 12:41 PM | #9 |
Did you take them apart in any way? The shoes? Sounds like your emregency brake bar is out of wack. Take that off and put things back together and see if that helps. it is the bar that runs across from shoe to shoe on the top half of the assembly with a spring on one side. Check that out. May just need to go through the brakes and rebuild them.
Good luck Chris
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
03-02-2018, 05:11 PM | #10 | |
03-05-2018, 09:20 AM | #11 |
Glad to help. I think of it as a return in kind of all the good help I have recieved here.
And thank you for posting what fixed it. Now the next person who has this kind of issue can find a solutions.
