Old 03-05-2018, 11:03 AM   #1
cebra
Speedo Leak - Bullet Replaced
I replaced the bullet on my TH350 and it is still leaking heavily. When I pulled the bullet, the speedo gear came with it and during reinstall, I noticed the gear was fairly loose in the bullet. I don't see anything stopping the flow from going between the speedo gear and the bullet and leaking out where the cable threads onto the bullet. I also bought a seal (ATP 2034 Speedometer Seal) but do not know where it goes, I assumed the new bullet includes this seal already. Any information or a schematic from cable to speedo gear would be great. I think I am missing a seal somewhere. Thanks.
cebra is offline   Reply With Quote
Old 03-05-2018, 12:19 PM   #2
geezer#99
geezer#99's Avatar
Re: Speedo Leak - Bullet Replaced
If that seal is a small o-ring it goes inside the bullet.
For some reason the new bullets don’t come with them installed already.
geezer#99 is online now   Reply With Quote
Old 03-05-2018, 01:54 PM   #3
cebra
That could be it, I thought the new bullet already had the seal in it so I didn't use this one. I will need to pull it out and check. On a side note, there are like 50 threads on speedo seal leaks which is how I found out about the bullet replacement but not much further. Here is a pic of the seal I have:
Old 03-05-2018, 02:15 PM   #4
geezer#99
geezer#99's Avatar
That’s the one.
I used a wood dowel to tap one into place.
Put a little oil on the gear when you slide it thru. Helps keep the seal from burning out on first use.
If it doesn’t stop the leak then you might need to replace the gear. They sometimes get a groove cut in them by that seal. Just a remote possibility of that.
Old 03-05-2018, 02:27 PM   #5
cebra
Excellent, thanks so much.
Old 03-05-2018, 02:30 PM   #6
cebra
Oh, just so I am sure, this is going in the back of the bullet (the threaded side) and the metal part of this seal is the part you tap in (the rubber going into the bullet)? Thanks.
Old 03-05-2018, 03:19 PM   #7
ga-stepside
ga-stepside's Avatar
Like this:
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 03-05-2018, 05:03 PM   #8
1969 Project
1969 Project's Avatar
Where did you order these from? I just noticed mine started to leak as well.
1969 Project is offline   Reply With Quote
Old 03-05-2018, 06:12 PM   #9
geezer#99
geezer#99's Avatar
You can get both here or visit your nearest transmission shop.
https://transmissioncenter.net/?swoo...-gears&paged=1
Old 03-06-2018, 12:49 PM   #10
cebra
I ordered mine off of ebay. The seal is on rock auto for 50 cents but their shipping is very expensive. The ebay seller I got mine from was a transmission shop. Bullet was $7, seal was $5.
Old 03-06-2018, 02:09 PM   #11
1969 Project
Do you happen to have a link?
Old 03-06-2018, 02:45 PM   #12
ga-stepside
I got mine 2 years ago off EBay, worked perfect no leaks since.
https://www.ebay.com/itm/TH350-TH350...QAAOSwMvtZVSOA
1967 C10 Step side
1970 AMX 390
Old 03-06-2018, 04:08 PM   #13
1969 Project
Thank you sir
Old 06-20-2018, 12:51 PM   #14
hotwls13
Does anyone know the factory "driven Gear" for my truck?? Or where I can find it? I have 3.07 rearend. 1970 GMC 1500 5.7 with TH350.
I'm trying to have all the parts BEFORE I start tearing things apart.
It looks like my Trans is leaking from everywhere (pan, speedometer gear housing, shift shaft and possibly more). I have all the seals/gaskets and filter to seal up the other areas. Picking up a new Gear Housing at lunch from local Trans Parts shop. They have "some" drive gears. Figured I'd grab a couple in hopes I get the right one.
I'm not so worried about speedometer accuracy at this point, just want to stop the bleeding (new truck to me, haven't gotten it on the road yet).
I jacked up the front of the truck a couple nights ago (engine is also leaking). Now getting lots of leakage out of speedo housing.
I'm assuming I can drain the whole trans by removing the speedo gear housing with truck on front jack stands?? Then move onto pan and shaft seal.
hotwls13 is offline   Reply With Quote
Old 06-20-2018, 01:21 PM   #15
slikside
slikside's Avatar
Sub'd.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 06-20-2018, 03:36 PM   #16
67 chevelle
67 chevelle's Avatar
Sometimes the "driven gear" gets a grove in it on the skinny end , where the oring rides , if it does it needs replaced
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 06-20-2018, 04:17 PM   #17
hotwls13
Yep, My trans is literally leaking from every seal, gasket, oring etc. I figure I may as well just track down a new drive gear so I have it beforehand. Tried the local trans parts house but they only had the larger 2" ones.
I've found them online but I'd rather not wait for the wrong part. Gonna try AutoZone (they are closest to my house but a bunch of button pushers) and Oreily's. If I strike out I'll just pull everything and order the gear I need after.
Old 06-20-2018, 05:34 PM   #18
1969 Project
I used a 9 tooth drive gear (green) and a 19 tooth Driven gear (natural) and my speedo is right on the money. The overall size of your tire also comes into play. You can get them at your local tranny shop or here http://www.laspeedometergear.com. He was pretty helpful when I spoke with him. Good luck!
Old 06-20-2018, 06:16 PM   #19
hotwls13
Yeah I wasn't planning on pulling the tail (so I won't know what color,or how many teeth) my drive gear has. Thought maybe there was a "standard" for 350 with 3.07 gears. :/
Old 06-21-2018, 09:01 AM   #20
jmj4
jmj4's Avatar
If you pull the speedo bullet, you can see the drive gear inside the tail housing with a flashlight to determine the color. You can look up number of teeth and go from there.
1970 GMC Custom 1500 SWB 307/TH350 3.73 Positrac
jmj4 is offline   Reply With Quote
Old 06-21-2018, 09:11 AM   #21
hotwls13
Awesome!! I wasn't sure if that was a possibility. Thanks for that pic.
