Old 03-07-2018, 02:09 AM   #1
Bablurp
Rear End Question
Newbie here. I recently acquired a 72 c20 and I will modernizing the drivetrain and doing a full restomod. It’ll be a 5.3l mated to a 4l60e. My question is if I would be able to swap in a 2008 Escalade rear end with 3.42 gears and 6 lug in place of the 8 lug rear end. This would allow me to use modern stock Chevy wheels and have rear discs. The front would obviously be swapped to 6 lugs as well.
Thanks!
Bablurp is offline   Reply With Quote
Old 03-07-2018, 03:36 AM   #2
bbrriiaann1973
Re: Rear End Question
I am sure the shock location would match up. But you could give it a try
Brian Ritter
bbrriiaann1973 is offline   Reply With Quote
Old 03-07-2018, 08:08 AM   #3
clay68c10
clay68c10's Avatar
Time to do some measurements, I like comparing the width at the wheel mounting surface. If it’s within an inch or 2, you are probably good to go.
You will probably have to move around spring perches and shock mounts.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 03-07-2018, 11:51 AM   #4
kwmech
I would focus my attention on a 14 bolt semi-float. Stronger than a 12 bolt
Old 03-07-2018, 12:10 PM   #5
demian5
demian5's Avatar
Yes you can put anything in there you want. Just get the spring perches installed correctly with the right pinion angle. You will more than likely need a new rear yoke for driveshaft but thats a given you will have the driveshaft redone anyways, along with redo shock mounts on rear end or truck, then the master/combo valve selection.
It can be done, but its not a simple deal. You may want to look into just swapping the axles to 5 lug and new discs.
Its only $$ right?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 03-07-2018, 02:35 PM   #6
Bablurp
I may end up going the axle swap route and doing 5 lug. I was originally intending on using late model 6 lug wheels as I’ve got 2 sets that I’ve yet to sell off.
Old 03-07-2018, 02:36 PM   #7
demian5
demian5's Avatar
Yeah if it was a 70 or earlier that would be cool, but I'd try and keep it 5 lug.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 03-09-2018, 01:28 PM   #8
Bablurp
What rear end is this?
Old 03-09-2018, 02:05 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Pretty sure that's a Dana 44.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 03-09-2018, 02:11 PM   #10
Bablurp
I'm going to assume this isn't a stock Rear end. The build sheet has it with 4.10 gears and I'm just now shopping around for rear end disc conversion as well as wheels. What would be my options on rear disc conversion?
Old 03-09-2018, 02:13 PM   #11
demian5
demian5's Avatar
Post pics of the SPID and Build Sheet
1986 C20 Scottsdale
Instagram: C10sofOC
Old 03-09-2018, 02:21 PM   #12
Bablurp
Here it is.
Old 03-09-2018, 03:39 PM   #13
outfield
That's a Dana 60 axle
outfield is offline   Reply With Quote
Old 03-09-2018, 04:08 PM   #14
Bablurp
Was this OEM or aftermarket? I apologize for all the questions. Just want to cover all my bases before I throw money into it.
Old 03-09-2018, 04:18 PM   #15
Bigdav160
Bigdav160's Avatar
That Dana 60 is OE and a little bit of a surprise as most Chevrolet's got the Eaton axle.
I would keep it. It's way stronger and has more aftermarket support than the AAM 8.5 axle in the Escalade.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-10-2018, 09:19 AM   #16
Bablurp
Thanks everyone! I’ll be keeping this rear end and converting over to disc after I refurbish it
