Old 03-08-2018, 02:52 AM   #751
MiraclePieCo
MiraclePieCo's Avatar
Re: What did you do with your truck today, Part 3
Since I'll be replacing my 700R4 with a Turbo 350 I'll have to make a new rear trans mount. So while I was taking measurements I thought I'd mock up the core support to double check my radiator-water pump clearance. Man, no need to worry - even considering the extra thickness of the pulley in there, I made still have to add a fan spacer.
MiraclePieCo is offline   Reply With Quote
Old 03-08-2018, 08:45 AM   #752
idbeast
I stripped everything off my front clip, and sandblasted it!
idbeast is offline   Reply With Quote
Old 03-10-2018, 02:08 AM   #753
MARTINSR
MARTINSR's Avatar
I got out to the garage tonight to get some work done on the truck. I am modifying the window glass frame to fit the chopped top. Instead of cutting a piece out shortening the back end of the frame I simply cut the 3.5 inches off and drilled a new hole and reshaped the end to match what was there. I lengthened the top of it 1.5 inches to match what I did on the roof. It's looking pretty good, hope I can get them good enough for chrome. This is pretty demanding, I have these frames, then inner and outer trim to make the same mods, wanting them all good enough for chrome. That is essential to the look I am after, to have them all chrome, we will see. I have a feeling I will be back up to speed when I am just finishing with the first ones not as nice as the last ones I do.
Not much, but a hell of a lot more over the last two nights than I have in months so I am feeling a little better about it.
Now if I can just keep it up!
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is online now   Reply With Quote
Old 03-10-2018, 11:51 AM   #754
Black_Sheep
Black_Sheep's Avatar
Got the custom tach I ordered from Speedhut installed and wired up. Now all of my gauges will
match...
Black_Sheep is offline   Reply With Quote
Old 03-10-2018, 05:19 PM   #755
MARTINSR
MARTINSR's Avatar
I got out to the garage and finished one of the window frames WHOOO HOOO! And it's chrome ready too, so happy I can still do it his stuff.
Brian
1948 Chevy pickup
Old 03-10-2018, 08:37 PM   #756
Black_Sheep
Finished body working both front fenders, they are ready for epoxy. One rear fender (minor) and two doors left to go.
Old 03-10-2018, 10:31 PM   #757
MARTINSR
MARTINSR's Avatar
"Finished" is always the best isn't it! When you get to use that is always the best.
Brian
1948 Chevy pickup
Old 03-11-2018, 09:24 PM   #758
Kevin Mac
Kevin Mac's Avatar
Upgraded tail lights with LED lens from classy Chevy. I thought the lens were good quality and $67 bucks so not too bad on price either. United Pacific was the brand of LED.
Kevin Mac is offline   Reply With Quote
Old 03-11-2018, 09:37 PM   #759
Kevin Mac
Kevin Mac's Avatar
Also built some stands using scaffold jacks and 1 1/2" pipe. I had a regular Jack stand drop on me while was under the truck a while back. Lucky the other stand held the truck and just teatered on it. Scared the heck out of me. So this has been on my list to do. For anybody doing a lot of frame work they work great. They won't lift a complete truck but will lift the rear with bed off or a rolling chassis. Threaded a couple and put a coupling and short nipple on so you could put a longer pipe to get them taller like a regular pipe stand.
Just need to finish the tops of the rest. They work good for metal cutting bandsaw to hold long pieces with a piece of C channel welded on top of screw.
Forgot to mention I bought the scaffold jacks from Northern Tools for $15 a piece. They are on sale right now.
Mac
Old 03-12-2018, 01:43 AM   #760
MARTINSR
MARTINSR's Avatar
Glad those worked for you. I tried some LED lights in my daily driver Rambler and they weren't as bright as the frigging stock 1157's.
Brian
1948 Chevy pickup
Old 03-12-2018, 01:44 AM   #761
MARTINSR
MARTINSR's Avatar
I finally got that damn window channel in the drivers door! WHOO HOOOOO!!!
It may have looked like a simple problem if you didn't have it in front of you but this was not a quick fix. I couldn't get into the door to see it's location, and it was damaged when I removed it without thinking, 20 years ago! Thank goodness I had the extra, stock door, I tried and tried to see in there to get some kind of measurement, no luck, it was just impossible to get anything, I gave up and cut a hole, solved that problem! And it wasn't even close to what I was doing so I am damn glad I did that. It still was a muther of a job, I must have pulled that sucker like putting a crochet needle threw a pot older out of the door modifying it and putting it back in about 30 times! Geeez, but it's in and done deal, the window looks perfect. Thank goodness my door has the extra hole from a speaker that I could get a little more access. I finished up by cutting the inner frame and shaping it as needed and it's ready for welding. Now all I need is to get my oxy tank filled.
One thing I screwed up on was I had an extra pair of window frames so I could eliminate one cut by using the other frame and cutting it long. I did this and couldn't figure out why it wasn't fitting well. I then took the pieces of the two fames to find out that one was a different shape! Geeeez, it was from a 51-54 and it had knotch cut at the bottom for the vent window used on the later truck. What I didn't realize is the whole thing was different because they didn't use the thicker window frame around the glass! So I cut up the darn thing I could have sold.
Brian
1948 Chevy pickup
Old 03-12-2018, 11:33 PM   #762
evilokc
ordered my vintage air kit. hope to have it for my week off. will be a perfect time to get some real progress made.
evilokc is offline   Reply With Quote
Old 03-13-2018, 01:48 AM   #763
MARTINSR
MARTINSR's Avatar
Got the door back on for the first time in many months, good to see it.
Brian
1948 Chevy pickup
Old 03-13-2018, 02:04 AM   #764
dsraven
looking good, like it was made that way.
Old 03-13-2018, 08:22 AM   #765
evilokc
yesterday I ordered my vintage air kit. ive got a week off coming up and it should be a great time to get it installed along with finishing up the interior lights. once that's done I may start getting it ready to run through the summer. I plan to put several thousand miles on it this year.
Old 03-13-2018, 10:17 AM   #766
MARTINSR
MARTINSR's Avatar
Thanks, that's the goal!
Brian
1948 Chevy pickup
Old 03-14-2018, 03:27 AM   #767
MiraclePieCo
Inspiring to see you still plugging away on the old girl, Brian. That's some fine looking metalwork on that top chop.
Old 03-14-2018, 09:42 AM   #768
MARTINSR
MARTINSR's Avatar
Thanks so much, I am back at it and it does feel good.
Brian
1948 Chevy pickup
Old 03-14-2018, 10:18 PM   #769
Slowy-gonzalez
I installed the rear big window on my 57 myself, only to break it at the very last second,
2017 king ranch power stroke
57 chevy big rear window, camaro front clip, rear is notched
57 chevy truck, air ride, ls swapped.
52 chevy truck waiting its turn.
Slowy-gonzalez is offline   Reply With Quote
Old 03-14-2018, 10:26 PM   #770
MARTINSR
MARTINSR's Avatar
Oh crap! Sorry to hear that.
Brian
1948 Chevy pickup
Old 03-14-2018, 10:28 PM   #771
vintovka
vintovka's Avatar
I had the one on my 54 successfully installed by a shop. I could absolutely not bear to watch or listen to the sound of hand slapping it in and the justifiable profanity. Sorry for your mishap.
vintovka is offline   Reply With Quote
Old 03-14-2018, 10:36 PM   #772
Slowy-gonzalez
sad part is, I was done, the glass was already installed, there was a small piece about 1/2 inch of seal that wasn't just right and I put a screw driver between the glass and the seal to pry the seal out and the rest is history,,,,,,
Old 03-14-2018, 10:55 PM   #773
evilokc
my vintage air kit showed up today. that was quick. I'm going to start the install tomorrow. I read through the directions completely. it doesn't look like its going to be to crazy to get installed. the directions seem to be pretty complete with several pictures. we shall see how it works out.
Old 03-16-2018, 02:58 AM   #774
evilokc
I got to start my install tonight. it didn't go as well as I wanted but its not a disaster yet. I got the defrost ducts installed, and started putting everything on the evaporator to get it ready to install on the firewall. I realized/ discovered I'm missing a few parts I thought I had. 1 hose, the a/c compressor bracket, and two hard lines for the condenser. I feel stupid that I over looked these parts but I will get it handled. I'm calling vintage air in the morning to order the parts. they got me the kit in 2days so I should still have plenty of time to finish the install.
Old 03-16-2018, 11:17 PM   #775
idbeast
After welding up all the unneeded holes in the bottom of the frame, grinding flat and cleaning up all the welds, I got the rest of the frame painted!!!
