Old 03-14-2018, 10:56 PM   #1
duramax55
hood adjustment on 55 2
Hi all what is the fix for hood that stays up in one corner when closed and have to push it down to close properly? Thanks Denis
duramax55 is offline   Reply With Quote
Old 03-15-2018, 08:39 AM   #2
bowt1ed
Re: hood adjustment on 55 2
You need to place a shim under the upper hinge to cab bolts. This rotates the pivot point a bit to allow spring to work properly. Usually an 1/8" shim will do it.
Cheers, Jim
bowt1ed is offline   Reply With Quote
Old 03-15-2018, 10:09 PM   #3
duramax55
ok thanks Jim will try that
Old 03-15-2018, 10:51 PM   #4
MARTINSR
MARTINSR's Avatar
You put a shim between the hinge and the hood at the front hinge bolt. OR you simply loosen the bolts on the hinge and push the hood open rotating the hinge back and tighten the bolts. You may then need to move the hood forward on the hinge.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
