Old 04-30-2004, 12:41 PM   #1
Deuce
Deuce's Avatar
Which 5 Lug axles will fit in a 68 Chev Diff
I bought a 68 Chev and a 68 GMC and I'm swapping out the front cross-member from a 82 chev truck.
But what I need to know is what 5 lug junkyard axles will fit into this diff?? What years of trucks should I be looking for??
I did a search, but didn't find what I was looking for.
Thanks.
I know what your thinking.......I have ESPN.
Sometimes it's easier to do things the hard way.
Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!!
Deuce is offline   Reply With Quote
Old 04-30-2004, 01:42 PM   #2
smokekiki
Mike
smokekiki's Avatar
Find a complete 71-72 rear .Might be the easy thing to do.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 04-30-2004, 03:57 PM   #3
boraxman
Keepin an eye out
boraxman's Avatar
You will need to have your axles redrilled by a machine shop or find a later rear end as suggested.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 04-30-2004, 03:58 PM   #4
Deuce
Deuce's Avatar
Are there no 5 lug axles that will bolt into the exhisting 68 diff??
Old 04-30-2004, 04:00 PM   #5
Deuce
Deuce's Avatar
Looks like I'll be pulling them out and sending them to the machine shop then. The 71/72 parts around here are scarce!!
Old 04-30-2004, 04:49 PM   #6
StingRay
StingRay's Avatar
You can buy aftermarket axles that will work. Up to some point in 70 the housings were narrower. Most 70 and everything after that till late 70's early 80's use the same housing width. Check with Scott in Penhold to see if he can hook you up with a complete 70-72 housing.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
