Old 03-22-2018, 01:30 PM   #1
ThunderTruck
NV4500 swap Muncie SM465
Im considering swapping my current Muncie sm465 for a NV4500 and just looking for general advice. Can i keep the stock clutch? Stock input shaft specs? How much do.i have to shorten driveshaft? Shifter alignment?
Any pther tips and advice much appreciated.
ThunderTruck is offline   Reply With Quote
Old 03-22-2018, 02:15 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: NV4500 swap Muncie SM465
Read this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=673588
LockDoc
Leon
Old 03-22-2018, 06:29 PM   #3
franken
You might want to search here, as well as go to Advance Adapters web site and get their conversion guide. As I recall 93-95 and 96 up are a bit different in the bolt pattern and reverse on the later trans had a synchro as well as a slightly less steep first, etc. 95 was a transition year if I recall so its a bit unique.
Oh, and Dodge used them so there are Dodge versions that I think need the input shaft replaced to work on GM.
clutch linkage, muncie od 65 c10 swap, nv4500 5 speed
