03-22-2018, 02:41 PM | #1 |
'64 EFI Rear Tank Options Help
I have done a lot of searching on a EFI compatible rear fuel tank for my '64. I just haven't been able to find everything that I am looking for in one tank. I would like to find a rear mount tank that doesn't hang down like a soggy diaper yet still offers decent range (20gal?), is compatible with EFI, compatible with a fuel sending unit to work with my 5.3 ECM, is not a bed floor fill, and doesn't cost $400 for just the tank.
I thought about the blazer tank as it is inexpensive, has a side fill, holds a decent amount of fuel, and can be bought with mounting straps. BUT, I don't like how it hangs down, don't know if it can be use with EFI, and if the fuel sending unit is compatible with my 5.3 ECM. Can you guys help me with some ideas that should work?
1964 Chevy C10 short bed stepside |
03-22-2018, 02:49 PM | #2 |
Re: '64 EFI Rear Tank Options Help
Boyd’s welding, best option imo!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
03-22-2018, 05:07 PM | #3 |
Sounds like a custom tank is in your future.
03-22-2018, 05:24 PM | #4 |
I have this one for you - fit perfectly in the frame but doesnt check all your boxes
03-22-2018, 11:13 PM | #5 |
60-66 Nut
You can use a universal tank or a vehicle specific tank.
http://www.tanksinc.com/index.cfm/pa...cat/cat133.htm http://www.tanksinc.com/index.cfm/pa...rod/prd249.htm http://www.tanksinc.com/index.cfm/pa...rod/prd114.htm I have also heard of guys using the '87-'91 Blazer or Suburban tanks. I'm just not sure if either of those will work in a short wheelbase truck.
03-23-2018, 03:23 PM | #6 |
Thanks for your ideas guys.
Jferrante: what are the details on that tank? I do like they have, just hoping not to spend $800 on a fuel tank and pump. Those links are helpful. It looks like some guys use early (1953'is) fuel tanks with decent results? Looks like a decent option for the cost if it goes together well.
03-23-2018, 06:59 PM | #7 |
I was facing the same dilemma, and I knew I didn't want to have a tank that hung below the bumper so I started this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=621177 I'm glad I did because in the end I got everything I wanted. Edit: wow I just looked back at that link and noticed how many pics that photobucket revoked. What a drag.
03-25-2018, 10:18 PM | #8 |
Junior Member
Copied from an old post of mine...
then edited for pictures... I didnt like the look or the fit of the blazer tank so I got a tank from a 87 or 88 work van. The van had a TBI motor in it so the sending unit was already setup for an intank pump. Its a 20 gallon tank. It hangs down about 7 in at the deepest point and the back of the tank tapers up, which makes it look nice from the back. I had to trim the bottom part of my frame rails about 1/4 inch for it to fit. I also had to move the rear crossmember back a couple of inches. I took it to an old school radiator/ gastank shop and had them soldered up the orignial filler neck and soldered in a new one on the top so the filler hose goes between the top of the frame rail and the bed. Then cut a hole in it to add a 0-30 ohm sending unit (20 bucks) for our stock gauge. I then loaded it up with an ep381 gm high pressure pump and its been supplying my 5.3 without any issues for over 10 yrs now.
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome." Last edited by Fastrucken; 03-26-2018 at 06:11 PM. |
03-26-2018, 12:15 PM | #9 |
hillbilly
How was this posted yesterday but the photos dont work?
-1962 C-10 |
03-26-2018, 02:30 PM | #10 |
But Found Her 25yrs Later!
I think it's based off a limitation. After so many photos, photobucket hides the rest.
I now just post my pictures through the tools these forums provide.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 03-26-2018 at 02:35 PM. |
03-26-2018, 05:32 PM | #11 |
The '87 GM van tank (p/n GM-8C) also has a built-in pan to prevent fuel starvation. I plan on using the same one for my swap.
03-26-2018, 06:16 PM | #12 |
Junior Member
Well the pics showed up when i tried it out last night hahah..
Anyways my setup still works bout 11yrs later, It was best solution i found with out having a custom tank made... The plan for the filler neck was to bend up some sheet metal and incorporate it in with the stake pocket.. Graham
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome." |
