Old 03-21-2018, 01:47 PM   #1
G-NUT
G-NUT's Avatar
I think my C10 rear axle has a 2.5? rear gear ratio / is this true
I was given a rear axle from my mother-in-law's boyfriend; it came out of a 1984 Chevrolet C10 2wd that he's had for years, but it's been sitting in his field for quite a few years. I just tried the whole mark the drive shaft yolk and wheel hub and spin / count thing from all the YouTub videos I've found, and what I seem to come up with is 2.5? . I have an open diff. I've never heard of a truck having a gear ratio higher than 2.73s. So is there a 2.5? that would have been in the truck. I asked the guy I got if from if he'd ever changed them out and he said no. There is no tag on the axle to help me identify what they might be.
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24.
/Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat /
SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed
G-NUT is offline   Reply With Quote
Old 03-21-2018, 03:15 PM   #2
mongocanfly
mongocanfly's Avatar
Re: I think my C10 rear axle has a 2.5? rear gear ratio / is this true
easiest way is pop the cover off and count the teeth....then divide...
my 85 had 2.73s...I thought that was high as tney went on trucks....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-21-2018, 04:50 PM   #3
G-NUT
G-NUT's Avatar
Took the cover off just a bit ago. Found a part number on the edge of the ring gear. The number is as follows:
W GM 1235401 16 41 10 83
Also, I counted the teeth on the ring gear and pinion gear:
Ring gear had 41 teeth
Pinion gear had 16 teeth.
Found a part number on my axle tube: BN3 G300 1
And two part numbers on my center chunk, one on the left and right of the center: what looks like GM36 on one side and looks like maybe 14055251 or 405525 on the other side. Not sure what those mean.
Old 03-21-2018, 05:00 PM   #4
Keith Seymore
Keith Seymore's Avatar
41/16 = 2.56, so that's pretty conclusive.
2.56 was the base axle in some configurations.
K
https://www.gmheritagecenter.com/doc...olet-Truck.pdf
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-21-2018, 05:12 PM   #5
mongocanfly
wow! 2.56s....I never knew they went that high on trucks...and I thought my 2.73s were high...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-21-2018, 05:40 PM   #6
G-NUT
G-NUT's Avatar
Thanks for the info.
I'm wanting to change to a 3.42 and a limited slip. Can I do this with this 10 bolt 8.5 axle that contains an open diff and 2.56 gears? I've read some say you can while some say you cannot.
Old 03-21-2018, 05:47 PM   #7
mongocanfly
use the rpm calculator before you decide on gearing..http://www.csgnetwork.com/multirpmcalc.html
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-21-2018, 11:05 PM   #8
Captainfab
60-66 Nut
You will just have to determine what series the carrier is for the 2.56 gears and whether or not there is a 3.42 gear set for that series of carrier. One of the many differential parts suppliers should be able to help you figure it out. According to what I'm seeing from both Yukon and Richmond, the carrier will need to be replaced with a 2.73 and lower carrier. You may want to verify that.
Old 03-22-2018, 01:45 PM   #9
61K10
61K10's Avatar
If going with a posi you are going to replace the carrier anyway. no problem.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 03-22-2018, 02:15 PM   #10
mongocanfly
^^^^agreed^^^^....new diff/new gears...problem solved
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-22-2018, 05:02 PM   #11
G-NUT
G-NUT's Avatar
Thanks for the information guys.
axle, gear, ratio, rear gear ratio
