03-28-2018, 01:03 PM | #1 |
Cab mounts question
Got a cab mount kit to replace the original mounts. I see where the front mount bolts are under the carpet. My question is about the rear cab mount bolts/nuts. Do you have to remove the fuel tank to access them?
Thanks in advance. |
03-28-2018, 03:08 PM | #2 |
Re: Cab mounts question
They're caged nuts on my 65. So no worries.
Everybody has to believe in something. I believe I'll have another beer. |
03-28-2018, 11:48 PM | #3 |
60-66 Nut
No you do not. The caged nuts are forward of the gas tank. The bolts come up from underneath.
03-29-2018, 10:53 AM | #4 |
Thanks guys. The new cab mount kit came with 4 bolts and 4 nylon insert nuts so wasn't sure if I needed to use them. I'll use the nylon insert nuts on the front and the caged nuts on the rear so I don't have to remove the gas tank.
Thanks! |
03-29-2018, 10:58 PM | #5 |
I just did the same thing. The bolts that come in the kit will not fit the nuts on your truck.
03-30-2018, 08:45 AM | #6 |
03-30-2018, 09:03 AM | #7 |
Moderator
I bought the correct size grade 8 hex head machine screws. But thats just me.
03-30-2018, 10:47 AM | #8 |
03-30-2018, 03:57 PM | #9 |
I did not move the gas tank.
03-30-2018, 04:01 PM | #10 |
You can take the old bolt to the hardware store. Get a new one then it will work with the old bolt. But then you can use the old bolt if nothing is wrong with it. I just wanted all new stuff.
03-30-2018, 04:34 PM | #11 |
What mount kit did you guys use? I think mine was one of those polyurethane ones.
03-30-2018, 05:05 PM | #12 |
But Found Her 25yrs Later!
Make sure you guys give a bad customer rating for the kits that didn't have the correct bolts included.
03-30-2018, 07:34 PM | #13 |
From car truck shop. part #60-09601
03-30-2018, 10:33 PM | #14 |
Just changed mine. Energy suspension Poly mounts. The rear bolts are bigger due to the size of bushings sleeve. Don't use the smaller bolt just remove cage nut with air hammer or long chisel etc. No need to remove tank. Use wrench to hold nut and zip tight with impact
06-21-2022, 11:40 PM | #15 |
This just came up again for me.
The rear cab mount bolts are a smaller diameter on my 65 than what comes in the kit.
06-22-2022, 01:34 AM | #16 |
Double
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 Last edited by Braunschweiger; 06-23-2022 at 01:39 AM. |
06-22-2022, 01:37 AM | #17 |
I did it on my '62 the same way Raylube described it.
The front bolts, from the kit, were a good 3/4" too short.
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
06-22-2022, 04:28 PM | #18 | |
I didn't want to cut out the cage nuts that the original bolts thread into. Maybe you could find an additional metal sleeve that takes up the slack between the original bolts and new mounts?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
06-22-2022, 04:52 PM | #19 |
Yes, a sleeve in the sleeve would be an option.
I did as you and used bolts that fit in the existing cage nuts. For me, the front mounts are so tight that I can't see the cab ever sliding.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 06-22-2022 at 05:14 PM. |
06-22-2022, 10:56 PM | #20 |
Hello everyone not to hijack this thread but I’m about to undertake this project this weekend… until I went to locate the front cab bolts inside the cab and it looks like a previous owner welded panels over the original floor.. if anyone can possibly give me some ideas without me creating a million holes to get to this bolt all help is appreciated.. I was thinking maybe I can jack the cab high enough we’re I can still remove the washers. Attached is an image from another forum member but similar situation. Thank you to everyone in advance. Maybe a possible exact measurement from a constant x and y location.
06-23-2022, 01:07 AM | #21 |
Couldn't you just drill up from the bottom?
06-23-2022, 06:42 AM | #22 |
Yes that would be an option my concern would be losing the bolt inside that panel and then it’s rolling around forever driving me crazy, since I’ll need to completely remove it in order to drill the hole
06-23-2022, 10:11 AM | #23 |
He can't actually do that, if it's the original carrier then there is a tubular sleeve there, the bolt goes through there.
Can you see it on the Pictures?
06-23-2022, 12:39 PM | #24 |
so the plot thickens. Guess i don't have many options besides drilling out a hole large enough to get the bolt out from the top
06-23-2022, 04:58 PM | #25 | |
Then, you will need the recessed washer for the bolt hole in the floor. . Check out this post: http://67-72chevytrucks.com/vboard/s...81#post7454881 .
