Old 03-31-2018, 06:52 PM   #1
Andy4639
Old member
Andy4639's Avatar
Thumbs up Almost
I loaded up the ramp truck yesterday with my 2 Schwinn chopper bikes and 1 pedal car to take to the Greenville SC Car's & Coffee this morning. It didn't make it but I got it back home and drove the 71 instead.
When we got back home I looked at everything under the hood and the only thing I could figure was the HeI was still running on the factory resistor wire. Sure enough after pulling the harness out and unwrapping it I found what I had thought. Stripped it out to the fuse block and re wired it to the HEI and it is running nice now. Maybe next month it will make it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-31-2018, 07:12 PM   #2
dmjlambert
dmjlambert's Avatar
Re: Almost
Good find. Mine was like that and ran fine for the first few months. Then I rewired it like this.
http://67-72chevytrucks.com/vboard/s...d.php?t=708975
Old 04-01-2018, 09:01 AM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Almost
That's what I did except I cut the resistor wire off at the connection and tied into it.
Took this on the way over before I turned around
Old 04-01-2018, 09:55 AM   #4
Faastone27
Faastone27's Avatar
Re: Almost
The 56 pedal car looks just like either of my 2 real 56's
Faastone27 is offline   Reply With Quote
Old 04-01-2018, 05:25 PM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: Almost
Those look good man!
I had the pedal car built for my dad's 56!
The pedal car is from Speedway motors for $169.00
Old 04-01-2018, 05:30 PM   #6
Andy4639
Old member
Andy4639's Avatar
Talking Re: Almost
Ok winch batteries are wired into the truck battery and charging. I put a contactor in line with the + cable to turn it on/off with from the dash. Lighted switch on dash lets me know when it's on are off.
May put a 50amp fuse in line with it also.
