Old 04-03-2018, 11:59 AM   #1
brown7373
brown7373's Avatar
Bumper alignment 1972
My front bumper is crooked...lower on the right side. I see no where in the Service Manual or the Assembly Manual covering adjustment. Short of loosening all the nuts and bolts, are there particular nuts and bolts to loosen so I can raise the right side about a 1/2 inch or so?
brown7373 is offline   Reply With Quote
Old 04-03-2018, 12:05 PM   #2
notsolo
notsolo's Avatar
Re: Bumper alignment 1972
I'm guessing the body is sitting level? I used large flat washers between frame horns and bumper to get bumper aligned with the body.
notsolo is offline   Reply With Quote
Old 04-03-2018, 12:13 PM   #3
NC_John
NC_John's Avatar
I have to do the same thing on mine. Had to do it the last time I had it apart and have to do it again this time. I used large washers between the bumper and the bumper bolts IIRC. Wish I paid more attention when I took it apart last year....
My frame is straight... body is straight, new mounts... Bumper crooked as hell!
I've been putting it off since its aggravating as heck to mess with.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 04-03-2018, 12:28 PM   #4
HO455
HO455's Avatar
After close to fifty years chances are something's tweaked. Our bumpers were not that stout from the get go. You just have to dive under and take a look at where the bolts sit in the slots to see if you are already out of adjustment in the direction you want to move. If you are out of slot in the direction you want to go, then the other end has to move to get things to back to level. I ended up loosening all the bolts on mine and tapping it in to position with a dead blow hammer and a piece of 2x4. When I was done I got it fairly level and most of the tweak out, but it had to sit a bit lower than I wanted it. The two center bolts are a pain to get at especially if some has changed the bolts out to longer ones. I had to lengthen the slot on one of the end brackets. It's easier with a helper to push and pry while you tighten the bolts down. A tape measure can help but sometimes it is best to step back and look from a distance if things are not very straight. A bad core support mount can cause the front clip to sit crooked making the bumper look wrong. So a quick check of those is in order before starting.
Good luck!
RIP Bob Parks.
Old 04-03-2018, 01:39 PM   #5
brown7373
brown7373's Avatar
I didn't see any slots, but maybe they will appear as I loosen some of the bolts.
