04-03-2018, 01:09 PM | #1 |
Has anyone seen the 4L80E speed tailhousing?
When I put a 4L80E in my truck i was confronted with the common problem of it not having a speedo output, so I use the electronic box that spins the cable for me driven by the TCM computer. I don't care for it, it's a little noisy and the cable bounces.
I should have done the 4L80E tailhousing with the speedo provision, but it was $695 for a tailhousing! I'm just wondering if anyone owns one or is familiar with it. I'd hate to choke down that price only to find out it's not a nice piece! Here's a link: https://transmissioncenter.net/shop/...iABEgJxyvD_BwE
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
04-05-2018, 01:57 PM | #2 | |
Re: Has anyone seen the 4L80E speed tailhousing?
4x4k30 if trouble was money i would have plenty |
04-05-2018, 02:04 PM | #3 |
meowMEOWmeowMEOW
4x4K30 I think your confusing it with the NSS switch. The VSS sensor is the thing your showing, but The thing the OP is referring to is a provision for cable-driven speedometers on our older trucks. The 4l80e never had (unless maybe in some fleet application I haven't seen) a factory gear/cable speedo drive. He's currently using the drive box (Cable-X?) to convert the factory VSS/OSS signal into a little servo motor which drives the cable speedo.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
04-05-2018, 02:50 PM | #4 |
Bruce (?) is right, I'm speaking of the tailhousing with the provision for installing gears and connecting a mechanical (cable) speedometer, which was never offered stock. That's why it's so expensive... $50 for a TH400 and $695 for this one!
04-05-2018, 02:56 PM | #5 | |
04-05-2018, 03:06 PM | #6 |
ok I was confused I just never did know everything about the vss when I swapped the 6.0and 4l80 in to my 77 it was all hooked together when I dropped it in .. so when I put just the 6.0 in my 79 with the turbo 400 I thought I didn't need to worry about the vss
04-05-2018, 03:08 PM | #7 |
Dave what brand of cable converter did you use ?
We used this one http://www.shiftworks.com/tailhousing.htm on my dads truck it was junk gears did not fit properly and it took a day in the shop to make it work. Were in canada so that price is closer to a $1000.00 Canadian once you get it in your hands your better off buying a electric cable box. https://www.speedhut.com/ecommerce/p...peed-Converter or http://www.dakotadigital.com/index.c...rod/prd886.htm
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
04-05-2018, 03:28 PM | #8 | ||
meowMEOWmeowMEOW
Everyone knows me as Rev Jay (or Reverend Jay if you like titles). Jay is also fine. Quote:
04-05-2018, 04:34 PM | #9 |
I used the dakota digital convertor box in mine. ..there's no noise and no bounce...it could be the cable between the box and speedo needs lubed....mine works great and I wouldn't hesitate to use another one...and am fixing to on my current project. ...I have my box mounted under hood so that may make some difference..
04-05-2018, 05:36 PM | #10 |
Yeah, I didn't do mine, the guy who installed the trans did. Nice tidy work but he mounted the box under the dash and the cable has a bendy path I don't care for. I should try just a long cable in a loop and see if it helps.
